Last edit by: IB Advertising
Browse all: Steering and Suspension
Browse all: Tires and Wheels Guide
- IS ES GS: Lowering Modifications
Important information to help you understand your Lexus
- How to Mount a Tire to your Rim
Step by step instructions for do-it-yourself repairs
- Tires General Information and Specs
****Official Wheel & Tire Fitment Guide for SC300/SC400****
#616
#618
im looking at these ruff 278 http://cgi.ebay.com/ebaymotors/Ruff-...40980566QQrdZ1 the size is 18x8.5 front, 18x9.5 rear +20 offset for the front and rears. From reading thru these forums +35 makes the rims flush with the fender. So +20 should stick out 10mm, correct? I am going for an aggressive look, but would this look to aggressive for a stock body? Also can someone recommend tire sizes. I am willing to roll the rear fenders, but would rather not roll the fronts.
thanks in advance.
thanks in advance.
#619
1UZFE/2JZGTE
thanks in advance.
thanks in advance.
#620
thanks in advance.
thanks in advance.
Slam it to the floor, and your setup will be sticking out 3mm more than what you see below:
![](http://www.tonywin.com/clublexus/acleansc4soarer-03.jpg)
Same thing for the fronts, with 8.5 +20, you'll be fine if you are slammed. Be prepared to roll front & rear fenders if you want to stick on a fat tire.
I am not running a lot of neg. camber either and I am using a 245 tire on a 10" wheel.
Good luck.
#627
#630
