Last edit by: IB Advertising
Browse all: Steering and Suspension
Browse all: Tires and Wheels Guide
- IS ES GS: Lowering Modifications
Important information to help you understand your Lexus
- How to Mount a Tire to your Rim
Step by step instructions for do-it-yourself repairs
- Tires General Information and Specs
****Official Wheel & Tire Fitment Guide for SC300/SC400****
#632
I'd like a flush look simular to Detuneds GS above
#633
it's not stretched, it's squared....but if the wheel fitment doesn't require stretching, like above, it can look decent. Unless you are planning on rocking a crazy wheel fitment, you don't need to go with a stretched tire setup. (it might look worse...in the end) What offsets are you thinking with the wheels?
#634
I'm still researching offset, not too versed on wheels/offsets. I'd like to be flush with the fenders and I'm willing to run some neg camber - not too much though.
Looking to fit a 275-295 sized tire.
What would you recommend?
#635
Where are yall guys and girls getting these sexy wheels in the states from. Where did you get the SSR Minerva from. Just wondering were do yall special order them from a few web site would be great.
#637
thats looks like a pretty mean stretch though. i would'nt call that mild at all but it looks hella sweet. im looking to get mines around there.
#639
Cherplex and Roo, you know I highly respect your opinions and knowledge of wheels, offsets and tires but I have to (IMO) correct you guys (and I don't mean to disrespect you guys in anyway) I just feel that we need a chart or explanation of some sort...
Since the VIP fad has hit the US, people are pushing the envelope on how much tires can be streched on wide wheels, Japan has pushed it pretty far, running 225s on 11 inch wheels, which looks nice but crazy (IMO), with that said I think we need to inform the members of what is the reality of what streched means (there is a big gray area)
People that are into wide wheels with low offsets don't really think that a 275 on a 10.5 wheel is not streched at all but the fact of the matter is...it is streched. People mention square; a squared tire is streched. The recommend width on a 275 tire is a 9-10 inch wheel which produces a sidewall buldge.
Obviously, we all have our own variations and opinions on what is streched and what is not. but we should start by taking a basic model wheel with the recommend tire size and go from there.
Though I don't really know what Technics considers streched?? I would think that the best way to inform people is to post pics of wheels with tire like we're doing in this thread. Great job guys!
Back to my point if we take a 10" wheel and put a recommend tire size on it (275) and use that as our base, then 275 on a 10.5" wheel is considered...a mild strech.
The SSR Minervas are from my white SC that I had back in '01, you're gonna have a hard time finding a set of Minervas now days. You'll have better luck finding a set of Strusses or Sovereigns.
Just tryna help out our members! peace - tann
#640
The problem is that all tire manufacturers usually slightly different measuring points and they also use different construction. This means the same size tire but a different brand on the same size wheel, will stretch completely different.
How much of a stretch is very subjective as well. Just do what you like![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
antk1 I also machined the rotor hats 2mm to bring them in more. I will be machining the backs of the wheels as well to bring them in more. Hopefully over the winter.
#642
wow i didnt even think of doing that. how much would a machine shop charge to do that? and what is a safe amount to shave off of the rotors?
#643
Front:
Volk GTC 18x9 +42
245/40/18
Rear:
Volk GTC 18x10 +44
275/35/19
They're a Face 1/Face 2 combo, but I can't remember which is which right now. The fronts will clear big brakes though.
Suspension is and will stay stock.
Slight rubbing under hard accelleration/big bumps. Barely noticeable though. We'll see how it is in the spring when I hook it with some power.
I'll get some pics up one day...
Volk GTC 18x9 +42
245/40/18
Rear:
Volk GTC 18x10 +44
275/35/19
#645
I don't think that will look so hot. It's going to be pretty aggressive on the front and conservative at the rear. You should go with more aggressive rears to match the front or get some more conservative fronts to match the rear.
