SC- 1st Gen (1992-2000)
Old 12-12-14, 04:39 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering and Suspension
Browse all: Tires and Wheels Guide
Print Wikipost
****Official Wheel & Tire Fitment Guide for SC300/SC400****
Old 03-09-07, 03:38 PM
  #871
Duckness
Duckness's Avatar
isnt JoshFSM running 18x11 on his sc300 ccw's? wouldnt i still be able to run 11.5 with rolled fenders?
Old 03-09-07, 03:56 PM
  #872
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
it's not really the width of the wheels, its the width of the tires... and if you are looking for traction, there's not much point in running a really wide (11.5") wheel if you are stuck with a 265 width tire...
Old 03-09-07, 04:03 PM
  #873
Duckness
Duckness's Avatar
if i am getting a good deal on the set of wheels, would i be safe with 305's?
Old 03-09-07, 04:20 PM
  #874
roo
roo's Avatar
listen to what mitsu is saying...i've got 18x11 in the rear but with 265's....
Old 03-09-07, 04:27 PM
  #875
mitsuguy
mitsuguy's Avatar
nope... not without a pretty rowdy pull...
I originally had 295's on the rear and they rubbed pretty much unbearably... might have gotten away with it if I had had a little higher offset wheel, but with 9.5" wide and +35 offset, and rolled fenders, I couldn't have lowered the car...
Old 03-09-07, 04:39 PM
  #876
Duckness
Duckness's Avatar
so is there a big difference in the supra rear wells and the sc300?
Old 03-09-07, 04:51 PM
  #877
mitsuguy
mitsuguy's Avatar
yes.... there isn't nearly as much room
Old 03-09-07, 07:10 PM
  #878
kaifiji
kaifiji's Avatar
so according to the last 58 pages or so, 18*10 with 45 offset should fit in the rear with only modifications being fender rolling on stock suspension. well my don't, it rubs on the suspension, even when the rim is right on the edge of the studs. i think i might have to run like 20mm spaces, if not 25mm. anyone know why?
and would i be crazy to wrap these rims up with 315/30R18 with spacers and fender rolling(stock suspunsion)?
Old 03-09-07, 07:20 PM
  #879
mitsuguy
mitsuguy's Avatar
Originally Posted by kaifiji
so according to the last 58 pages or so, 18*10 with 45 offset should fit in the rear with only modifications being fender rolling on stock suspension. well my don't, it rubs on the suspension, even when the rims right on the edge of the studs. i think i might have to run like 20mm spaces, if not 25mm. anyone know why?
and would i be crazy to wrap these rims up with 315/30R18 with spacers and fender rolling?
tire size tire size tire size....
you should be running a 275/35-18 with that size wheel...
Old 03-09-07, 07:27 PM
  #880
kaifiji
kaifiji's Avatar
295's is the minimum i wana put under there. want all the meat i can get!
Old 03-10-07, 12:41 AM
  #881
red400
red400's Avatar
Originally Posted by Blizzy
I have 19x9.5 in the rear. I PMed mitsu during my entire wheel decision-making process. He insisted that I should go with 275's instead of the 265's that I had slated in. I trusted his opinion. At the moment, my rear tires are my favorite aspect of my entire car. It makes the car look so authoritative. If I had your car and your rims, I would go for the 275's.
I also have 19x9.5 R and 275's.. i think they look aite, but i was thinking a 285's would look better,no? wouldnt it look stretched mmore?
Old 03-10-07, 06:09 AM
  #882
np20412
np20412's Avatar
if you want stretched you need a smaller tire, like a 255 or 245 on a 9.5 but you wouldn't need to stretch unless your offsets are really low
Old 03-10-07, 07:04 AM
  #883
mitsuguy
mitsuguy's Avatar
285's would be wider, yes, and it would look more bubbly...
using BFG's specs (which are pretty similar to everyone elses) -
275's go on 9-11" wide wheel, 9.5" being optimum...
285's go on 9.5-11" wide (depending on profile), 10" being optimum....
you guys should really look at manufacturers rec specs...
Old 03-10-07, 11:10 AM
  #884
mitsuguy
mitsuguy's Avatar
Well, problem is tire diameter too... even though it may be a little bubbly, I would still go with 275/35-18 as this keeps the stock gear ratios and speedometer in check (less than .5% difference) I run 275's on my 9.5" wheels and to me the tire is an absolute perfect fit...
for the front, however, I run 255/35-18 I wanted something wide, and it's definitely wide, and fairly close to correct diameter (it's a little smallish), but looks good (click on signature pic)... If you stick with 245's, go 245/40-18, I would not go with 235's on the front at all...
mine is lowered a little over 2" and I had to roll the rear fenders to make it work... not bad at all though...
Originally Posted by Maeve
Cody,
Since you're familiar with BF Goodrich g-Force T/A KDW2 ...
Do you think I should go with 275 or 265 on 18 X 9 wheel for the rear?
The offset is +35.
From this photo below, a 265 g-force KDW2 already looks bubbly on 18 X 9 wheel:
( I copy paste the image from this thread in the classified section)
I don't mind to roll my fender if that what it takes to get a 275 tire when I drop the car with Tein SS.
Basically I want a "fat" set up for my rear & I'm planning to get BF Goodrich g-Force T/A KDW2 for the front and rear.
One last question ...
The front is 18 X 8, offset is +35 ---> should I go with 235 or 245?
Thanks bro
- Dom -
Old 03-10-07, 11:37 AM
  #885
Maeve
Maeve's Avatar
Thanks for the advice, man.
I will go with 245/40 & 275/35 (BFG KDW2).
I figure the rears will look bubbly on the sidewall, but that is the look that I'm looking for.
I just want to make sure that a (BFG KDW2) 275 will fit on 9" wheel.
The other day I saw a Falken tire 275 on 9" wheel, but the sidewall looks square,
I don't really like that style.
Btw, do you have a close up picture on your rear?
I saw you posted it (in the other thread) a while back.
- Dom -
Quick Reply: ****Official Wheel & Tire Fitment Guide for SC300/SC400****
