SC- 1st Gen (1992-2000)
Old 12-12-14, 04:39 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering and Suspension
Browse all: Tires and Wheels Guide
Print Wikipost
****Official Wheel & Tire Fitment Guide for SC300/SC400****
Old 05-29-07, 10:14 AM
  #1081
Kohinoor
Kohinoor's Avatar
Originally Posted by VGnomore
Rim Brand and Type: Works VS-XX
Rim Size f/r: 19x10.0(75mm lip) /19x11.5(112mm lip)
Rim Offset f/r: et21 r-disk/ et29 o-disk
Tire Size f/r: 245/35/19---285/30/19
are you sure yours are 10 +21 and 11 +29??
i have 10 +18 235/35 and 11 +18 275/30 and i have a 25mm pull in the rear and im about to get +25mm vertex fenders for the front since it sticks out more than an inch
Old 05-29-07, 12:56 PM
  #1082
VGnomore
VGnomore's Avatar
They are 11.5s in the rear.I guess it is true that different companies measure offset differently. Yes I am sure That is the sizes because I had them made to the exact set up I wanted when D-2 autosports had there march madness sale. I must say works measure there offsets more accurate to how toyota does because I measured using tt wheels for strut clearance and it was dead on when I got them (4mm to the strut) Just like the tts P.S your car was my desktop pic forever Hoebag.
Old 05-29-07, 01:17 PM
  #1083
Kohinoor
Kohinoor's Avatar
its possible my offsets are more aggressive than what the seller told me. there arent any stickers for my wheels that show offsets, but i used http://www.1010tires.com/WheelOffsetCalculator.asp to compare my friends fitment on his sc with 9 +26 and 10 +26 and the difference is about 22mm out on my rims.. which seems about right
i dunno.. i need to measure the backspacing i guess
Old 05-29-07, 07:28 PM
  #1084
VGnomore
VGnomore's Avatar
Yeah if there are no stickers on it them measuring the backspace will give you the answer your fronts look to be around 10 and the rear looks mid teens.
Old 05-31-07, 06:44 AM
  #1085
scenery
scenery's Avatar
Originally Posted by mitsuguy
ouch, yah, huge difference that 6mm makes...
I would get an alignment done, then measure for a spacer... alignment will have a small affect on how much space you have for tire/wheel...
are you kidding me? based on alignment alone you may vary your tire/wheel fitment as much as 20mm
Old 05-31-07, 07:11 AM
  #1086
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
I wouldn't say 20mm, maybe 10 or so...
I run -2.6 in the rear, and theres about 5mm difference from -1.0 negative camber (which is considered within stock tolerances)... Not many people are going to run more than -2.6, so, 5-10mm total... I suppose if you go crazy with like -4.5 or something, sure, 20mm, but lets be reasonable, about 1 in 5000 SC owners will actually run that much negative camber...
Old 06-01-07, 07:03 PM
  #1087
rwdpwr
rwdpwr's Avatar
ok guys im looking for a set of wheels that might be too ambitious for stock fenders.
they are...
18x9.5j -3
18.11j -4
i was wondering if i could be able to fit these if i slam it with like 2deg neg camber on back with a roll and pull...btw its probably going to stick out an inch past the stock fender so theoretically a 1in pull should make these fit "flush"? thanks
Old 06-01-07, 08:56 PM
  #1088
mitsuguy
mitsuguy's Avatar
they are...
18x9.5j -3
18.11j -4
hahahahahahah
absolutely not...
unless your tires are 3 inches narrower than the wheel...
I run 19x9.5 with +35 and with -1 degree camber rear, it was dead even with the fender, now that I run -2.6 degrees, it's got 5-10 mm extra space... yours will stick out more than 2" more than mine... again, unless you are running a narrow tire, it just isn't gonna fit, even with a pull...
Old 06-03-07, 12:38 PM
  #1089
VGnomore
VGnomore's Avatar
they are...
18x9.5j -3
18.11j -4
Just look at turbotegs set up to reference your sizing your rears would sit almost identical to his and you will need to go with the vertex front fenders as well.It is do-able but by no means practical.By the way why sacrifice the 46mm of space that you will have between your wheel and strut?
Old 06-03-07, 10:01 PM
  #1090
rwdpwr
rwdpwr's Avatar
thanks for the replies, gave me more insight on what ill be cookin up...
i guess im going to have to look for another set of wheels in the lower positive offsets...
Old 06-05-07, 08:38 AM
  #1091
RedPhoenix
RedPhoenix's Avatar
19x10.5 +35mm can I still a 275 with some slight camber on that?
Old 06-05-07, 09:13 AM
  #1092
mitsuguy
mitsuguy's Avatar
with rolled fenders, yes
Old 06-05-07, 10:00 AM
  #1093
emoshun
emoshun's Avatar
I will post up some pics of my setup as soon as its installed! Hehe... just wait!
Old 06-06-07, 09:36 AM
  #1094
kyoso23
kyoso23's Avatar
Car is lowered on Espilir ASD w/Daizen camber kit
235/35/20 on a 8.5" w/-42 (front) cut fenders and -1 camber
275/30/20 on a 8.5" w/-42 (rear) cut fenders and -1.5 camber
TitanG545 (07-26-20)
Old 06-06-07, 05:33 PM
  #1095
AME_VIP
AME_VIP's Avatar
VGnomore nice setup with the VSXX! Love the kit too. I wish my JIC fit that well.
Hoebag I agree I think your fronts are more aggressive than 10 +18. They look closer to 10 +/- 0 if they stick out 25mm.
Quick Reply: ****Official Wheel & Tire Fitment Guide for SC300/SC400****
