SC- 1st Gen (1992-2000)
Old 12-12-14, 04:39 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering and Suspension
Browse all: Tires and Wheels Guide
Print Wikipost
****Official Wheel & Tire Fitment Guide for SC300/SC400****
Old 06-06-07, 09:03 PM
  #1096
IIJZSC300
IIJZSC300's Avatar
guys i just got my rims and they sent me the wrong ones they sent me 18x9.5
all around and they have a 25 offset what should i do. and what mods should i do to make it fit also tire size i need help across the board thanks ps the rims are work emotions if that helps
Old 06-08-07, 11:15 PM
  #1097
VGnomore
VGnomore's Avatar
Roll the fronts 245/40s
Roll the rears 265/35s
Happy modding Sir
Old 06-10-07, 09:56 AM
  #1098
Rising_Sun
Rising_Sun's Avatar
Would 19 x 9 +15 fit in the fronts of our cars?
Old 06-10-07, 11:38 AM
  #1099
Kohinoor
Kohinoor's Avatar
Originally Posted by TurboTeg
VGnomore nice setup with the VSXX! Love the kit too. I wish my JIC fit that well.
Hoebag I agree I think your fronts are more aggressive than 10 +18. They look closer to 10 +/- 0 if they stick out 25mm.
they stick out more than 25mm
fgts lied to me
Old 06-10-07, 02:58 PM
  #1100
VGnomore
VGnomore's Avatar
Yes It will fit with a roll. 19x9 +9 is the same as my 19x10+21 So you are safe
Old 06-12-07, 07:32 AM
  #1101
lmucklow
lmucklow's Avatar
Default Need Help
Will the following fit on my 1992 sc400
SET OF FOUR NICHE Custom 18 inch rims, road wheels, 8.5 X 18, mounted with 2 Yokohama 295/30ZR18 94Y (rear 11 inches wide) and 2 Yokohama 265/35ZR18 97Y (front 10 inches wide) tires. Five bolt pattern, will fit 1994 - 2004 Ford Mustang. Good condition. Call for pictures. $550.00. obo. Edmonton.
Old 06-12-07, 08:09 AM
  #1102
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
probably not... whats the offset?
Old 06-12-07, 09:03 AM
  #1103
lmucklow
lmucklow's Avatar
im not sure, what are my limitations without having to do any mods?
Do you know what is the widest tire i can use?
Old 06-12-07, 09:30 AM
  #1104
mitsuguy
mitsuguy's Avatar
it depends on the offset... without any fender mods, and with the exact right offset and wheel width, 275's would probably work... 295's will fit with rolled fenders and the right offset and wheel width
Old 06-12-07, 07:51 PM
  #1105
soarinhigh
soarinhigh's Avatar
does anyone know if 17x9 with +20 offset will work out?
Old 06-15-07, 05:08 AM
  #1106
prophetsc
prophetsc's Avatar
what size tires should I run on some (stretched)
18x9 -20 fronts, 18x9.5 -27
and will I have to do fender modification
Old 06-15-07, 06:08 AM
  #1107
mitsuguy
mitsuguy's Avatar
negative offsets?
hah
I wouldn't want to quote tire sizes without knowing what wide body kit you plan on running...
Old 06-16-07, 08:00 AM
  #1108
Chawk60
Chawk60's Avatar
Mitsuguy,
I have read this thread from start to finish and it has changed from it's original concept to what is now. Rather than a place to see nice rim/tire sets with spec info, and for people to draw what they need from the posts, it has turned into <mostly> a Q&A. I needed some info for my setup and decided to take advantage of what has already been posted, so I think I have a good idea of what I should do. I wanted to thank you for volunteering your experience and making the effort to answer the voluminous amount of querries that are here. I am sure you have helped alot of people...I just wish some folks took the time to read rather than ask a question which has been answered previously (3x, 4x, etc).
Thanks again!
Old 06-16-07, 10:04 AM
  #1109
mitsuguy
mitsuguy's Avatar
Originally Posted by Chawk60
Mitsuguy,
Thanks again!
Thanks man! I appreciate the acknowedgement... I deal with this stuff every day, so it's really no big deal to me, and I hate to see people get screwed with wrong sizes, or what they ~don't~ want, so I try to help out as much as possible...
Keep em comin!
Old 06-17-07, 04:17 AM
  #1110
toyofreak
toyofreak's Avatar
Name: ADR Decadence
Size: 19"x8.5" (front), 19"x9.5" (rear)
Bolt Pattern: 5x114.3
Off Set: 20mm (front), 25mm (rear)
Finish: Gloss Black with Polished Lip
They say it would fit our cars, but I have a hunch it would stick out a bit. Your take?
Quick Reply: ****Official Wheel & Tire Fitment Guide for SC300/SC400****
