Thats pretty cool! The photo really threw me off, I had to look at it at least 3 times before I realized what car it was, whether it was the LS or SC. In any case, thats a wicked little mod.
Has any one else done this, have pics, know of estimated price, list of parts needed...It's a sweet mod to those ugly dildomatics
There is a part list on this board posted by one the members here I found before doing this. I'm not sure who posted the parts diagram. But I do know it's on this board I think I searched for gated shifter.
1. (P) Green Wire, Shift Lever at Left Side
2. (D) Brown Wire, IG Switch On and shift lever D, 4 position = 10-14v
3. (SPD) White Wire, IG Switch On, shift lever D or 4 position and vehicle speed more than 11 km/h (6.8 mph) = Below 2v
4. (ACC) IG SW ACC = 10 – 14v
5. (IG) IG SW ON = 10-14v
6. Red wire to shift lock switch
7. White wire to shift lock switch
8. (KLS+) Blue/White Wire, IG Switch on and shift lever P position = Below 1.5v
9. (E) Black wire, Ground
10. (STP) Yellow wire, Depress Brake Pedal = 10-14v
gadgetSC
I am currently working on my gated shifter.... the wiring is easy, just follow the diagram above and you won't get lost.
I got the shift lock working... I press the brake pedal and the shifter disengaged. It's pretty nice
I have a couple of questions though, does anyone know where I should tap the + and - wires for the lamp? Please see diagram above.
Also I need to know where I should tap the wire from #2... I emailed gadgetsc and he's kind enough to PM me back. He mentioned wire #2 goes to 12V... does that mean I should run it directly to the battery?
