SC- 1st Gen (1992-2000)
Climate control non functional
Old 07-09-07, 08:54 AM
nyARISTO
Sunroof Surfer
nyARISTO's Avatar
Default Climate control non functional
i have searched and searched for climate control problems, but no one has posted answers on how it was fixed ... yes i see lots of ways of checking for diff. fuses/ wiring diagrams... but no answers...
Here's my prob. my climate does not turn on at all no type of power screen is completely off yes i have checked all the fuses and the plugs in the back and traced back wires( well not completely) but where do i go from here, i have changed all relays realating to this... car has fully charge A/C and its 100 deg. now and it sux in the rain cuz i cant see shti......
Help! HELP!
-TONY
Wrong section..... can a MOD move this to the main SC 400/300 section
Old 07-09-07, 08:57 AM
plex
1UZFE/2JZGTE
plex's Avatar
Borrow another one and plug it up and see if it comes up. There are enough SC's up there to find a lender lol
Old 07-09-07, 09:07 AM
nyARISTO
Sunroof Surfer
nyARISTO's Avatar
i allready tried 2 units... i have 2 extra now both work i tried on a working SC also (yes it was from a black one)
Old 07-09-07, 09:12 AM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
does it have power? you said you traced wires, but did you actually put a voltmeter to the power and grounds to make sure the unit was actually getting power?
probably a bad climate control unit...
Old 07-09-07, 09:30 AM
nyARISTO
Sunroof Surfer
nyARISTO's Avatar
Check post above
No i didnt check if it had power or did i put a volt meter in it to check for power
Old 07-10-07, 01:07 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
42 and 43 are switched power and ground
Old 07-10-07, 01:29 PM
nyARISTO
Sunroof Surfer
nyARISTO's Avatar
Hmmmm so i See , i will look after work thanks brian
Old 07-10-07, 08:45 PM
CLNSC3
CLNSC3's Avatar
I would say look for a coin in the cig lighter, but you already said you checked the fuses...good luck!
Old 07-11-07, 05:02 AM
aliga
Former Sponsor
aliga's Avatar
are any of the radio wires chopped up?
Old 07-11-07, 10:14 AM
<>sonmylex
<>sonmylex's Avatar
well its okay. you could just give me your car... i dont mind the climate control problem =)
Old 07-11-07, 05:12 PM
nyARISTO
Sunroof Surfer
nyARISTO's Avatar
its not the radio wire allways stock n yes only 1 wire use to tap for amp...
but i figured it out whats could be wrong i will post up when fixed!
Marisa only if i get a lifetime of unlimited vente non fat white moca with no whipp for freeeeee! n then some
Old 07-16-07, 08:39 AM
<>sonmylex
<>sonmylex's Avatar
hahaha you could have that already. you just dont come in to visit!
but okaaayyy if thats what you want LOL
Old 11-21-07, 10:30 PM
vntperform
vntperform's Avatar
What if the radio wires were chopped up?
Old 11-22-07, 12:00 AM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
It's all circular dawg....... the head bone connects to the neck bone.
Old 11-26-07, 03:16 PM
vntperform
vntperform's Avatar
:lol:
Quick Reply: Climate control non functional
