sc400 windows sticks
Hello room! (93) SC4oo has problems with the window controls. Right side started first only working when it wanted to. Then it stopped working all to gather. Now driver side has started same issue will fail down and not roll up, but if you switch the car off and back on again it will roll up! Help needed on ideals to fix this?? Thanks in advance.
When it does work does it go really slow or is it normal?
If it goes normal when it does work I'd say the window switch itself is going bad. My passenger side window moves along really slowly and I'm guessing it's the motor itself.
