ECU LexusSC400.com, Clearing things up
I am back to talk about the ECU for the V8 to set all you straight!
We have been busy trying to get some other parts made for for the SC's, therefore not having been on the forum to explain in detail what our ECU offers.
We apologize for any inconvenience.
Please understand that we are not here to talk bad about any company/ or competitor, even though some people have been taking cheap shots at us. We are here to clear the air and provide clear and accurate data about the products that we provide. NO TRICKS OVER HERE....WE PRACTICE WHAT WE PREACH WITH CONFIDENCE!!
LSC400.com ECU:
Our ECU is the only one of it's kind done in the U.S. for the 1UZFE not 1ZUFE as stated in weapon-r's dyno sheets.
Since everyone is talking about the piggy back system Leo @ weapon-r is making, we can compare ours to that for you.
Our ECU is not made for Japan, it is simply a program written by a Japanese programmer with over 20 years experience in programming mild to wild ECU's. He also programs for 250 different dealers many of which you know. We can't mention who he programs for because the companies are so large. Major companies at the top.
He and his team worked over 3 weeks to produce this ignition program that adds real world results. He has done this to over 50 of the SC400's V8 motors here and in Japan.
I have personally spent over 3 months convincing him to offer us his services. Our programmers are teaming up with Area 51, to program for a super charger application for our car. We already have a ecu program for those who would like to "Juice/ Squeeze".
It will be available at a reasonable price, and this is no B.S. like some other companies like to put out. We don't string people along! LexusSC400.com are True enthusiasts for the True enthusiasts!!!!!! We only run/ promote products that we have ourselves..
Back to the ECU v.s. Piggy Back (oink)
Our programmer can sell you a piggy back system tuned for less than anyone else if you like.
A piggy back system is restrictive in the fact that you are limited to only one program setting. For example: if you want to run NOS, you need to tune for that. Your everyday driving will be worse than stock because you need to retard the timing for the forced induction.
Our ECU is plug and play. We program the actual computer chip and not try to trick the signals on the way in and out. With piggy back systems you have to splice the harness and tap into wires. This leaves alot of room for error. If one of your connections becomes loose or grounded, your car will be inoperable and possibly fry the computer.
On piggy back systems and our ECU you can tune the Air/Fuel ratio and remove the top speed limiters if you like. This is done on the other side of the computer (go here) http://www.lexussc400.com/lexussc400/computerpics.htm
Changing the Air/Fuel ratio has not proven to produce major horsepower gains and is not worth the money.
If you need to reprogram our ECU it will cost considerably less after the first mod. After that, your chip is easily removable.
We can setup two programs, one with a safe but aggressive timing program, and one with the stock program. If you want to smog your car or just run stock settings, you just connect the two wires coming out of the computer.
Real world results can be found by talking to one of our 9 customers on the ECU in the last month.
Adam Butler ran 15.9 E.T.'s without our ECU upgrade.
HE RAN 15.0 WITH OUR ECU UPGRADE.
Our ECU causes the car to shift at a higher rpm as well.
HellasBoy also has the upgrade and LexLuther is on order.
We are offering these ECU upgrades at $899 with single program
and $1099 with the dual programs.
We are providing a safe upgrade which will not effect your driveablility and only enhance your performance to its fullest potential.
Please send inquiries to info@lexussc400.com
We are very busy with upgrades and need to schedule yours in so please arrange with us.
WE GUARANTEE SAME DAY SERVICE!
Please visit our revamped site that loads much quicker.
We have MAF adapters from HKS in stock.
Once again, sorry for not keeping you guys up to date.
I'd also like to take the time to introduce Chad as our New Sales Manager and you can reach him at:
salesteam@lexussc400.com
When you buy from us, your money is going towards making new performance products available for the SC, not the GS or IS!
Smooth8
LexusSC400.com
Building a better SC together one mod at a time.
LSC400.com ECU:
Smooth8
LexusSC400.com
Clara13
04-08-16 06:59 AM
