SC300 Main Fuse
SC300 Main Fuse
EDIT: Got the correct part second time around. This time I got a parts guy that actually knew what I was talking about. For future reference, the part number is 9098208270 and it costs around $14 from Longo Lexus.
So I was looking into the fuse box and noticed the main fuse looked a bit crispy so I decided to change it out. Well it was so brittle that it broke into pieces. I go to get a replacement at the Lexus dealer and they give me a
100a fuse that does not fit. I have been to Toyota/Lexus and various auto parts stores with no luck of finding one that fits. Anyone know where I can get the correct fuse?? I need it asap since the car does not run without it. I don't want to "make" the new fuse fit.
You can see how the one that came out of my car is squared while the new ones are rectangular. Also the base is different as the new one does not slide into the slot and the the holes are too small for the bolts.
So after visiting several auto parts stores I went back to the Lexus dealer (Longo Lexus) as a last resort and was helped by a parts guy that actually knew what I was talking about. The first guy in the morning was unwilling to help and he just said that the smaller one is all they got. On a side note, my passenger foglight that was not working started working again (via this thread: https://www.clublexus.com/forums/sho...d.php?t=301523) after I replaced the main fuse. I'm not sure if the main fuse was the issue, but I'll see if it goes out again.
I searched my problem and found this thread so I'll wake it from the dead instead of creating a new one. Decided to tackle my underhood fuse box. I open it to find a wonderful gift. Busted main fuse and a blown up cover. The metal parts were kind of twisted together in ghetto style. Trying to remove it proved impossible as the metal portion seems to be welded in. The part number that the OP mentions is described as FUSIBLE LINK. WIRING & CLAMP #9098208270 for LEXUS. I thought it was just a 60A fuse; from that above description it seems the fuse box will need to be removed so I can remove the wire from the underside. However OP didn't mention that and the FSM just describes it as a fuse that can be pulled and replaced. What gives?
WTF?
WTF?
Figured it out. Most of the big fuses have bolts running through them. So I just had to lift the sockets. Good thing they are sections because the plastic was damaged on the main fuse bolt so that explains the solder on the blown fuse. Heading to the junkyard in hopes they have an SC that isn't just frame. Will post pictures later.
Lucky Me! They had a 92 SC400 with a fusebox that wasn't hacked off. Main difference is color of plastic and the lack of space for extra fuses. I'll search for a 95+ model on a future trip as I'd really like those slots for extra fuses.
Old Fuse holder - left side
Old fuse holder - right side (Alternator cable loose)
New fuse holder - All wired up!
Car cranks right up and my gauge cluster needles aren't dim!
When you say “bolts running through them” what do you mean? I destroyed the popped fuse trying to get it out and still haven’t figured out how to yank it.
Golo1949 (06-25-22)
aznkorboi
10-13-14 05:38 AM
