Horn and Cruise Control not working
08-30-07, 11:42 PM
So i just got done installing my new all black 1995 lexus sc steering wheel. and all of sudden the horn stopped working. it worked at the begining and then when i spun the wheel all the way around i heard a click nd crack nd then the horn nd cruise control didnt work. anybody know wat the problem might be?
08-31-07, 07:12 AM
there is a fuse under the hood that controls the horn. It actually also controls the hazards also. If your hazards are not working as well, I bet you simply broke a fuse.
I am not sure if cruise control is on that fuse or not, but it might be.
08-31-07, 08:33 AM
i checked all the fuses and they were fine... my hazards work... its just the horn nd cruise control.
08-31-07, 03:39 PM
Sounds like when you put the wheel on, things weren't lined up properly and now the contact ring has broken/moved or the connector has pulled itself out somehow.
08-31-07, 03:53 PM
pull it off and inspect for damaged or broken pieces. Replace those that are.
09-18-07, 10:46 PM
this is old sorry. but yeah i have had a chance for much yet. anyone have any idea? where to look? problem?
09-19-07, 12:14 AM
Quote:
Originally Posted by
schwarz
Recheck your installation.
09-27-07, 09:41 PM
still no luck im going to have to check the wiring but i have no clue how to get to it.
09-28-07, 12:10 PM
Former Sponsor
your clock spring is most likely bad, i have one for 35 shipped.
the clock spring transfers the signals from the horn cruise, etc down thru the steering column.
09-28-07, 01:08 PM
Lol Gazi to the rescue.
aliga
09-28-07, 01:55 PM
aliga
is it easy to install?
09-28-07, 01:56 PM
Former Sponsor
jattunit24
take out the airbag, and install, simple as that.
09-28-07, 02:23 PM
really. how much wiring? and how easy is it to pull the part out?
09-28-07, 02:26 PM
Former Sponsor
jattunit24
wiring is built into the unit, so as the wheel turns, the wires turn as well. basic hand tools will do the job.
09-28-07, 02:29 PM
alright i think im going to hav to order that part. but imma look at those tail lights too so we can combine shipping also a cupholder for the middle.
DONT SLEEP
Performance & Maintenance
34
07-06-17 11:13 PM
Jerpam
04-07-16 08:42 PM
Devor
SC- 1st Gen (1992-2000)
03-05-11 05:35 PM
mischief7
09-02-08 03:32 PM
messysc
11-06-04 05:39 PM
470 ,
control ,
cracked ,
cruise ,
fuse ,
hazards ,
horn ,
is300 ,
lexus ,
ls400 ,
not ,
problem ,
problems ,
sc400 ,
working
