What did they do to my cluster?!
Okay, so last night I pulled the cluster out of my car to check on the fuel gauge (per suggestion from O.L.T.). The 5 screws were tight so I'm guessing my problem lies in the fuel sending unit in the trunk.
My car has always had an issue with the odometer. It either shows the first 3 numbers or the last 3 numbers, and if I go over bumps it'll blip between both sides. With the cluster off I see that the screws that hold that chip down are only halfway screwed in! Also, one of the wiring clips had tons of old electrical tape on it covering up a busted plug and wires that look like they're about to come apart.
Aside from the fuel gauge needle being dead and the fuel gauge not working at all, and the issue with the odometer, the cluster works fine. However, seeing this little wiring mess, should I just get a new one? Try to fix this one? Put the electrical tape back on it and pretend I never saw it? I'm going to send a cluster off to Lextech eventually and don't want to waste their time and mine with this one if it's messed up.
Thanks guys!
Thanks guys!
I'd love to know. The car was bone stock when I got it. My friend that I got it from has been known to ghetto rig stuff from time to time but from when I was around he never dug into the car much until I got it from him.
I'm pretty handy with a soldering gun if I need to repair this stuff...I'd love to just get a new one but I don't want to spend $200 on a cluster to turn around and spend another $250+ at Lextech with it.
PS- the screws on the odo being loose do not make a connection to anything and have no bearing on the effect.
Jonny
