SC- 1st Gen (1992-2000)
Picture Time!
Old 09-16-07, 04:35 PM
iasc300
iasc300's Avatar
Originally Posted by Black_SC
if you cut your springs, you're a retard...
dont go the cheap way- do it right
Old 09-16-07, 04:44 PM
100mgbluep
100mgbluep's Avatar
Originally Posted by DZLEXIK
Looks nice, i always liked that color...where did you get your emblems?
Thanks, they used to be gold but painted em black
Originally Posted by NYe36er
Espelir's run $235-$250 depending on where you buy them. They lower a bit over 2" all around. Gives the car a great stance (slightly raked).
Where can i get some of these?
Originally Posted by Blizzy
I am running Swift Springs for the Supra. They drop the SC 1.9F/1.5R. They are top of the world in durability, and the spring rates favor a very comfortable ride for a drop spring while still increasing cornering stability at the same time via progressive spring rates.
I can't speak highly enough about them. At ~$310, they are slightly more costly than the competition; but, they are worth every penny from my experience.
Click on the photo of my car in my sig to see the stance. There is a slight rake to favor the mean -rather than the luxury- side of the car's personality. The drop will change your love for your car completely.
Your car looks great. I like how you are keeping it simple.
As a side note, an MDX Antenna (~$30 at locustoms.com) will get rid of that stock antenna that stretches 75 feet into the air when you have the radio on. It will mesh well with your black badges.
Site to get the springs =? Also, locustoms.com doesnt work is the site is down..
Originally Posted by Fireblaze
Nice car, but the pinstripes have to go
I have no problem with the stripes, i think they add a sense of "flare"
Originally Posted by sc300max
I too am running the supra spec Swifts, but mated to supra spec Bilsteins. I don't have alot to say since Blizzy has pretty much said it all heh.
Another question is how do you want the ride to feel? Smooth? Sporty?
Here are some of my experiences with different spring/shock setups:
The Swift setup will give your ride that sporty feel. The springs have a progressive rate so the ride isn't too harsh at all, but slightly bouncy going over uneven roads. As far as how low it sits, I have to be careful on driveways and speed bumps, but dips are no problem.
Another setup I have tried was the supra spec Tein H-tech mated to the same Bilsteins. Lowered it about f:1.2"/r:1". Ride was pretty rough and bouncy on uneven roads since the springs had a linear rate. I had no scraping issues on driveways, dips, or speed bumps with this setup.
A combo that I have never tried, but seems to be good on paper is the oem MKIV Supra TT springs mated to Koni Yellows Sport. The springs will lower the SC about 0.5" all around and the Konis have an adjustable spring perch so you can lower it even more f:20mm (~0.8")/r:15mm (~0.5"). It should give you a total drop of about f:1.3"/r:1.1" without sacrificing too much of that stock ride quality.
Theres alot of good info on this site so don't hesitate to search and hope you can share your thoughts on the setup you go with.
Im really leaning torwards the smooth ride since the roads around here are terrible. I really like the way my car rides now so id hate to lose any smoothness...
Old 09-16-07, 05:07 PM
Kohinoor
Kohinoor's Avatar
you could heat up your springs and compress them haha
Old 09-16-07, 06:23 PM
Blizzy
Blizzy's Avatar
If you drop, you will loose smoothness: there is no way around it really. Tein CS Coilovers would likely do the trick, but they are not cheap at all.
I really like the Swift Springs. I bought them from ebay: Quality Japanese Parts was the seller's company name. The springs are not on ebay all the time, but when they pop up, they are ~$309 with no shipping charges. When it comes to a lowering spring, the numbers say Swift should be about as decent a ride as you can find.
I am also on Tokico Illuminas, which offer some dampening adjustment. I found the settings 1 and 2 too bouncy. The dampening was not in line with the spring rates. Settings 3 and 4 really ride nice. The dampening will not get "out of phase" with the springs and get bouncy. Setting 5 is quite stiff: too stiff for daily driving.
As for locustoms, they may have went under. I know the antenna is from an MDX. A call to your local yards might surface one. It is pretty much a direct bolt on so long as you get the proper-sized washer at your local hardware store.
Old 09-16-07, 08:07 PM
SC30096
SC30096's Avatar
so If I chose to go with the swift springs do i hafta change my shocks as well or can I still just run them on stock... whats the ride like if I did do this?
Old 09-16-07, 08:11 PM
TheMole
TheMole's Avatar
When you use supra spec springs you need to use supra spec shocks.
Old 09-16-07, 08:43 PM
bighitbike
bighitbike's Avatar
Ah my GWC buddy finally came to the good side!!
Beautiful car man...
Old 09-16-07, 08:48 PM
Seize
Loves Snickerdoodles!
Seize's Avatar
Lookin' good!
Old 09-16-07, 08:56 PM
100mgbluep
100mgbluep's Avatar
Ive had her for a while, just couldnt post up pics until i got rid of the retarded wheels it came with. Thanks for the complement
Originally Posted by Seize
Lookin' good!
Thanks
Old 09-16-07, 09:19 PM
slappy96
slappy96's Avatar
Default Looks Good.
Where in AR? I'm from Hot Springs.
Old 09-16-07, 09:21 PM
100mgbluep
100mgbluep's Avatar
Faytown
Old 09-17-07, 02:05 AM
DasBach
DasBach's Avatar
Hey, clean ride. We have the same color car and badges! I painted mine black just before I left, brings back memories :P
Old 09-17-07, 02:50 AM
Matador
Matador's Avatar
the website for the antenna is www.locustom.com ...no "s" at the end.
Old 09-17-07, 03:58 AM
bigmalik00
bigmalik00's Avatar
you might not like the feel of a lowered car... cheap way to find out is get some Supra TT struts.
Old 09-19-07, 09:32 PM
100mgbluep
100mgbluep's Avatar
So in order to do tunable springs or w/e, do i need to buy supra struts?
Quick Reply: Picture Time!
