Automatic SC300 to 6 speed possible?
How easy is it to take a SC300 auto and convert it into a 6 speed manual? Is it very different than going from 5 speed to 6 speed?
Also what is the last year you guys recommend going to for a SC300 model for turbocharging?
Chicago Lexus Club Moderator
I think when you're turboing your car any year is fine.
It's not very simple, and certainly not cheap. You'll need an all new pedal assembly (had to wait forever from Japan), master cylinder, slave cylinder, hydraulic line, 6spd tranny, clutch, custom length driveshaft, (rear gears will be very steep and should also be changed), etc, etc, etc.
sc300tt is correct....not easy and expensive but doable......as for the stock auto tranny...they can handle around400+rwhp with a shift kit.....the best year is a 95...last year OBDI and has all the tunnel clearance for the 6spd with no modification......Jeff
6spd, 6speed, auto, automatic, conversion, converter, converting, driveshaft, length, lexus, sc, sc300, speed
