SC- 1st Gen (1992-2000)
Tonight's project - interior paint
Old 10-01-07, 11:22 PM
Gunnar
Gunnar's Avatar
Default Tonight's project - interior paint
Here's a little story in pictures of what I did tonight in breaks on helping my roommate with his car.
Here's my dirty car about a week ago, with the 3-spoke SC300 steering wheel and the all tan interior:
Then I put my 98+ Supra wheel on, and noticed that the steering column just wasn't going to cut it in tan.
So at work I picked up some of this:
And upon reassembly we got this:
I only used a few coats, as I wanted it to stay dull enough to look factory. I was pretty pleased with how it came out.
As you'll notice, the center console was removed too. I painted it and the cup holders, and here is the final result:
The rear cup holder was my "test piece" and ended up getting painted 3 times before I was willing to tackle the noticeable pieces, and even so I didn't even use a full can of the VHT paint. (and yes I know my interior needs cleaned up)
Old 10-01-07, 11:28 PM
menty
menty's Avatar
did you sand it or anything or did you just spray it?
Old 10-01-07, 11:41 PM
Gunnar
Gunnar's Avatar
I used watered down Simple Green to clean the pieces really well before I painted them. I gave each piece of the steering column a couple of coats, the center console ended up getting 3 coats.
Old 10-02-07, 12:11 AM
Curry
Curry's Avatar
I like it. Looks good. Now clean your car!
Old 10-02-07, 05:10 AM
StiCk3
StiCk3's Avatar
that actually looks quite nice! I might try this when converting my tan supra seats to black...the first try really didn't get the result i was looking for
is it a semi-gloss paint or something else?
Old 10-02-07, 06:06 AM
RedPhoenix
RedPhoenix's Avatar
black parts looook good
Old 10-02-07, 06:31 AM
kaotiq
kaotiq's Avatar
I don't know about you guys, but I'm digging the custom cup holder where the radio used to be.
Old 10-02-07, 06:43 AM
sc250tt
sc250tt's Avatar
+2 .Gunnar have you looked into using the leather/Vinyl dye. I painted some panels on my last sc400 and after a while i noticed it started flaking .I used dye on my Glove box and it held pretty well on there .The paint usually have a tendancy to flake since it dont penetrate like the dye does Its looking good though p.s .selling that supra wheel?
Old 10-02-07, 08:44 AM
TheMole
TheMole's Avatar
Looks pretty good man. Now you can finish the dash, window trims, rear trims for that black/tan conversion.=)
Old 10-02-07, 09:06 AM
Neucorp
Neucorp's Avatar
What are your plans for the tan *****, flasher button, and text above the *****? Seems like that will be a pita to change.
Regarding paint vs dye, I read a post a while ago about something called molecubond. The company has changed names to colorbond. The product apparently bonds at the molecular level to change the color...so you would maintain the stock texture...and it never cracks or chips.
Old 10-02-07, 09:18 AM
Pezlo
Pezlo's Avatar
some orange soft scrub will clean up that leather very well! changed my from a faded grey to the oem tan color =]
Old 10-02-07, 09:23 AM
Gunnar
Gunnar's Avatar
I'm not really sure about the *****/buttons/text. I unscrewed those pieces and painted it without any attachments on it. I'd imagine those pieces would be hard to paint, I may just keep an eye out for buttons/***** off of a black interior'd car.
The paint was a bit of a dye I believe. It'd go on very glossy and sort of soak into the material and dull up and on the steering column especially it looks like a factory piece. It claims it won't flake off, and the pieces all retained the stock texture like you said.
Kaotiq, the previous owner took out the radio for some reason and the climate control was just sitting on the bottom of the DIN opening so I improvised.
Old 10-02-07, 09:31 AM
Gunnar
Gunnar's Avatar
Oh and the Supra wheel isn't for sale but if anybody wants the 99-00 SC300 wheel it's a definite improvement over the stock 4-spoke, even if I didn't figure out how to patch up the airbag.
Old 10-02-07, 12:42 PM
1JZ300
1JZ300's Avatar
smooth keep the pics coming, i was one of the guys who wanted to convert my int to black...looks nice, MORE PICS
Old 10-02-07, 08:44 PM
twin lex
twin lex's Avatar
I would also like to see more pics of the interior, only after the detail gets done
Quick Reply: Tonight's project - interior paint
