G35 19" wheels
I found some 2006 G35 Coupe wheels for a good price.
Does anyone know If these wheels will fit without modification.
The sizes are:
Front 19x7.5 225/40/19 offset??
Rear 19x8.5 245/40/19 offset 33??
not sure what the offset is on these wheels.
The sizes are:
![](http://i188.photobucket.com/albums/z256/Scpwner/G35rimsside.png)
![](http://i188.photobucket.com/albums/z256/Scpwner/G35rimsside2.png)
![](http://i188.photobucket.com/albums/z256/Scpwner/G35rimsfitment.png)
For reference on an SC.
I dont think that is correct. I believe the Front set are 19x8 and rear 19x8.5
Do you know if he had to Roll the fenders or anything??
I saw that thread, but I need to know if I can just bolt them on or if I need to take them somewhere to have the fenders rolled?
They will bolt on. I have them on my SC and they fit just fine. I'm not riding on factory spec tires though. 245/30/19 in the front and 245/35/19 in the rear. I have BARELY 1 finger gap in the rear on STOCK suspension. I paid $630 for mine with basically new tires BTW.
I will buy yours for $631... they look good. So suspension it looks good in the back but what about in the front? And are you running a thicker tire? i don't really know the difference in tire specs ( haven't really paid much attention to them). Also post up some pics of your ride for another reference ![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
This is the wheels by the way:
![](http://www.sarahdan.com/LexusSC400/g35Wheel.jpg)
![](http://sdcc15.ucsd.edu/%7Ebjen/rear1.jpg)
This is my rear with 245/35/19 Potenzas. If you're running stock, your sidewall will be slightly bigger. I think it'll be 1/2 of an inch bigger but you shouldn't have any problems. Be sure to get wheel locks and take off those Infiniti wheel caps.
They'll fit fine with the Potenzas that come on the G35, but if you lower lots you'll have rubbing issues. On the rear, my fender lip shaved off the letters on the outside of the rear tires, and on the front I rub pretty bad whenever I'm turning and hit a bump. To fix the rear I went with a 235/35/19 tires, hasn't rubbed since and puts the speedo back to what it should be for it's closer to the stock diamater unlike the 245/40 that comes with the wheels. I've just been living with the rubbing up front for the past year, but next spring I'm going to go with a skinnier and shorter tire. Oh btw I'm lowered on Espelir ASD springs with tems struts.
People often tell me the wheels look way better on my car than they do on the G35!
Does anyone know how far off my speedo will be with these?
