New Sig
What do you think? Hopefully it will be done in time for TX2K2 Supra meet. It has been in the works since September now, most of you know the old setup so I am sure you can see that this is basically all new stuff![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
-Ethan
-Ethan
looks like fun...what did you dyno previously?....just boost and with nos?......and what are you hoping to dyno now...with boost...and then nos?.....thanks Ethan and good luck on the wild ride
and the HKS manifold??.....are you on a TT head?.....how did you get that to work?....and did you do a custom intake manifold?...Jeff
Last dyno was 662RWHP on the bottle (~29psi). It was like 52x off the bottle if I remember correctly. I am hoping for high 800s/low900s at the wheels. We are just using to NOS as a spool up now to 20psi. I am using an N/A head. The HKS Manifold is the same one we were using... It is the TT manifold with a different flange and upper few inches of runners welded in. We were using the stock manifold... We MAY go to TT intake manifold with the SP upper piece to gain some power and also to make changing plugs easier.
We are beginning to believe that the stock intake manifold may be a limiting factor, so are hoping to pick up some power with the TT manifold if we do it.
Anyways, hopefully I will be able to show it all off soon and get some times/dyno numbers.
-Ethan
-Ethan
i dont think the manifold is as limiting as the cams......what are you doing about the cams?......?...what turbo?....sounds like you got some major work being done........i agree about the plug changing
.......i cant wait to see the 9sec beat....give us some respect in the supra neighborhood...Jeff
I agree that the stock cams are limiting also. They are not that small of a profile though, so there has to be something else and we think that is it. The new motor will have a fully ported head, custom cams from crower, and the different intake manifold, so hopefully every restriction is gone![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
-Ethan
-Ethan
OOOOoooo....nice! What stroker kit are you using....I've seen JUN that's 3.3 and Crower that's 3.4.
I've gotta get one asap, I've got other problems that have arisen with mine. :/
SR
SR
As for the head...you had it ported. Is that really an issue with this head, or does it add minimal HP? I heard that the NA head is MUCH better than the TT head for turbo'ing, bigger ports and stuff I think.
And how much cam are you running? Will crower make more sets of them if I just call and ask?
Your setup is just looking more awesome every time I look at it.![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Thanks!!
SR
Thanks!!
SR
I think at the point my car is at now the head is definately and issue. Extra displacement and massive turbo with stock head just doesn't seem matching to me![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
As far as the cams go I am not sure... I told them I wanted 272s, and they said they would see what they could do. They called the other day to say that they were done, and they were shipping them out, but the guy who called had no idea what they had done to them. I plan on calling tommorrow or tuesday and talking to Brian (Crower) to see what was done.
I will let you know if they can make more. I am sure they can, they will just need a set from you.
-Ethan
-Ethan
-Ethan
-Ethan
ThankS!!
SR
