My Intro to CL: This is how bad of a driver I am
#50
no idea what i'm putting down yet, just haven't had the time to dyno. plus, i need to install the MBC.
Originally Posted by JDMmuscle
Do you have LSD?
Originally Posted by jgdynamics
how is that w58 holding up with the clutch in the low 400hp levels?
#52
alright, lovely wife got me some side skirts for xmas (well, i found them, she payed for them but it's the thought that counts).
![](https://lh3.ggpht.com/_exP0VHBXW7Q/SXKiMxxFlTI/AAAAAAAAB4E/jL9Sbb5duFE/s400/IMG_0445.JPG)
![](https://lh3.ggpht.com/_exP0VHBXW7Q/SXKiNVOrVVI/AAAAAAAAB4I/ojgKw7lfgIo/s400/IMG_0446.JPG)
![](https://lh4.ggpht.com/_exP0VHBXW7Q/SXKiOrV3mwI/AAAAAAAAB4Q/IUKPY_xMCzc/s400/IMG_0448.JPG)
![](https://lh6.ggpht.com/_exP0VHBXW7Q/SXKiPZs-9KI/AAAAAAAAB4U/Lz9OU2FpEC0/s400/IMG_0449.JPG)
![](https://lh4.ggpht.com/_exP0VHBXW7Q/SXKiP7fCt9I/AAAAAAAAB4Y/6msbmaT5fPU/s400/IMG_0450.JPG)
the color is a bit off on the skirts but that's because my car was resprayed by the previous owner. final thing is to repaint the whole car and i should be done! it's only taken me about 2 years to get to this point. =)
#57
another update: i had the stock w58 shifter modified so it would be a little further back. i was going to bend the shifter per my post here: Strength of Metal
unfortunately when i was trying to heat the shifter, it melted the rubber holding the top damper piece on. so i had to go another route. i had the top piece welded back on but towards the rear of the shifter, as well as a little lower than stock (welds aren't great but it should hold). i didn't take any good pictures before installing but i just took this so you can see it:
![](https://lh5.ggpht.com/_exP0VHBXW7Q/SX5aFZh9jCI/AAAAAAAAB5Y/GiTi12IyDDg/s400/IMG_0471.JPG)
here's how it looks with everything installed once again. as you can see, it sits right in the middle in neutral.
![](https://lh5.ggpht.com/_exP0VHBXW7Q/SX5aGLnmoYI/AAAAAAAAB5c/avEFLDP-6MM/s400/IMG_0472.JPG)
as compared to this:
![](https://lh5.ggpht.com/_exP0VHBXW7Q/SGfi6iUzwEI/AAAAAAAAAhQ/APHpHwxO6b8/s400/Lexus%20061.jpg)
g-force
02-25-02 11:10 AM
