parking light 1157 or 168?
is our bulb 168 wedge or 1157? sylvania has it listed as both I tried to reach the blub to pull out and check but I cant access it, battery is in the way on the right left side is just awkard or maybe im just retarded I dont know, but Im gonna order some LEDs but Im just really lazy to take out the headlight to check for what I should be ordering. thanks
I had a lot of trouble getting to the two side bulbs when I replaced them recently. Try getting some pliers, etc. to twist the bulb holder thing. They need to make them easier to unhook. I ended up breaking minor plastic pieces off of two driver's side harnesses with a flathead because the damn things wouldn't unhook and there was almost literally no room. I read some threads that recommended to just unhook the parking light bulbs for various reasons so that's how mine are now.
+1
Many people have replaced the stock bulb [168] with white LEDs to match their HIDs. I'm one of them.![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
Unless you have extremely small hands, it is probably best/easiest if you just remove the headlight housing and work on it to avoid breaking things from working in an awkward position.
well Im planning on changing the fogs to LED's as well so i think im gonna take the headlight out while my inner fender is pulled back thanks for the info guys
on a side note has anyone tried the LED fogs, whats the output like? and do LED turn signals work with our blinkers?
babowc
SC- 1st Gen (1992-2000)
14
02-27-14 12:56 PM
