DIY, Tutorials, How-To collection (MERGED THREADS)
oh man looks like i am bumping this thread thanks Dave...
very useful ex radio power button conversion
https://www.clublexus.com/forums/sc-4...ing-again.html
black pearl emblems
https://www.clublexus.com/forums/auto...e-emblems.html
clear corner lights
https://www.clublexus.com/forums/sc-4...er-lights.html
hyper blink fix
https://www.clublexus.com/forums/sc-4...blink-fix.html
Lower control arm DIY
https://www.clublexus.com/forums/susp...l-arm-diy.html
gated shifter diy
https://www.clublexus.com/forums/perf...pre-98-sc.html
Smoke tail lights
https://www.clublexus.com/forums/sc-4...ked-tails.html
ls brake upgrade
https://www.clublexus.com/forums/susp...or-my-sc4.html
DIY dash removal...
https://www.clublexus.com/forums/sc-4...-56k-nono.html
black pearl emblems
clear corner lights
hyper blink fix
gated shifter diy
Smoke tail lights
ls brake upgrade
DIY dash removal...
What can happen if you "wash" your engine: The wall of Pain
The potential for unholy hell unleased by washing your engine :
a warning to all sc300 owners!!!
Washed my engin then....
washed engine bay - strange problem. need the experts
My buddy sprayed off his SC's motor and now its misfiring. Cause?
power washed engine and now missing on 4 cyl's
SC300 engine idles strange
help! engine shuttering
Help!!! My SC might be damaged!!!
for the second time in a row, I washed my engine
Water in Intake Manifold Spark Plugs
Bad Engine Skip
MISFIRE After Engine Cleaning
Degreased engine and it stopped running
If you cleaned your engine (1uz) and this happens....
UGhhh No power Sputter..SC3
Bad Engine Skip
Here is one.
http://www.max-boost.co.uk/max-boost/supra/turbo.htm
2jzgte sequential system thoroughly explained. Also has a plethora of information about intercooler sizing, crank ventilation, camshaft optimization, and a few tips on general maintence and performance.
SITE HAS INFORMATION ON TWO(2) ENGINES. MAKE SURE YOU ARE READING ABOUT THE RIGHT ENGINE
Hate to nominate my own thread but it's about time somebody did one on the subject.
https://www.clublexus.com/forums/sus...ac-delete.html
KC
KC
Another tire well harness relocation DIY. This one doesn't involve cutting the harness
www.clublexus.com/forums/sc-400-300/488672-diy-tire-well-harness-relocation.html
And my Push Button Start DIY
https://www.clublexus.com/forums/sc-...-ignition.html
Keeper of the light
Power steering valve rebuild/block
https://www.clublexus.com/forums/per...s-one-out.html
Heater core control valve substitute/replacement
https://www.clublexus.com/forums/per...rol-valve.html
Popping door hinge
https://www.clublexus.com/forums/sc-...7-seconds.html
Door panel fix
https://www.clublexus.com/forums/sc-...el-repair.html
Convert corner lights into fogs
https://www.clublexus.com/forums/sc-...og-lights.html
Shifter Led conversion technique
https://www.clublexus.com/forums/sc-...e-shifter.html
Everything to know about the cluster and climate unit
https://www.clublexus.com/forums/sc-...-clusters.html
A/C compressor removal/installation
https://www.clublexus.com/forums/per...tallation.html
Seafoam 101
https://www.clublexus.com/forums/per...k-in-here.html
Engine, tranny mounts V/S center driveshaft bearing
https://www.clublexus.com/forums/per...r-bearing.html
TPS sensor changes
https://www.clublexus.com/forums/per...ps-sensor.html
idling issues
https://www.clublexus.com/forums/per...look-here.html
(updated 7-11)
Popping door hinge
Door panel fix
Seafoam 101
TPS sensor changes
idling issues
(updated 7-11)
Hi, i'm a noobie on this forum. i was wondering. if i can learn how to change my fog lights on my 96 sc400. everything seems so complicated for this car..
and i am trying to change my own oil too. if u know can i please show me how? thanks!
i think this should be added DIY matte black emblems WITHOUT REMOVING THEM
https://www.clublexus.com/forums/is-...-required.html
i know it is in the IS section but i did this and it worked great
1 Post
Can anyone post a DIY aeromotive fuel regulator on a 1jz and how to replace sc400 fuel pump into walbro255? been searching a while now i jst wana make sure im doin all of em right.. thanks
Here is mine on wiring up an aux input to the stock stereo. Similar to PureDrifter's. Different in the aspect as to that this is straight to the point and the Cd player will not work.
https://www.clublexus.com/forums/sc-...ml#post5851680
My own take on the Tape Deck Hack/Auxiliary Input DIY. This allows for the retention of all the factory stereo features, with the added benefit of an auxiliary input to allow playback of ipods, mp3 players, phones, etc.
Auxiliary Input
Auxiliary Input
Here's something to try. Worked for me. Still need to do my window trim. It isn't specific to window trim, but you should get a good idea.
