19x11 +29 and 19x9.5 +24 fit?
i have posted in the wheel forum, but to no avail. would these fit on our sc's? the tire sizes are also 295/30-ZR19 Michelin Pilot Sport PS2s on the rear and 255/35-ZR19 Michelin Pilot Sport PS2s. i am looking at a set of brand new wheels this size for a decent price. so please let me know. thanks.
you will need a roll + little pull in the rear and probally a smaller tire in the rear. I am running 10.5 +22 with 275/35 with a roll and a pull. Your set up would sit 1mm less than mine. so it should be fine.
You will certainly need a flush roll on all four corners. You will likely need as much camber as the factory alignment rods will give you to make it happen.
The rear camber adjustment is pretty rangy in stock form, so it just may be possible to creep that 295 under the fender on a +29 offset. I am working a 285 on a +35 offset, and a +30 offset would rub; however, my factory alignment rods are maxxed in the positive direction for camber. Your proposes set up might be be crazy enough to work (although I would expect to have to pull the rear ~5mm).
ps. there is a wheel and tire thread that is stickied at the top of the forum.
LeeJonah
10-25-17 04:08 PM
