Wider opening doors????? Can the hinges be modified?
I am hopefully going to be getting an SC soon. I have a couple problems. First of all, I am paralyzed and the doors don't open very wide for ease of entry. Has anyone messed with the hinges to make the doors open wider? Secon thing is the seat doesn't recline all the way. I assume that is as simple as drilling out a stopping pin in the seat reclining bracket?
Thanks in advance,
Jon
Thanks in advance,
Jon
Yeah, those hinges are burly! They look like they belong on a tank. I'm suprised they wear out. I will have to try and modify the driver side one though or else it is too hard to get my wheelchair in and out.
i wouldn't mess with the hinge, It is designed to open wider without taking as much room as a regular hinge, notice when you open the door how it moves forward and outward, that is not just by luck, it is design.
Well, without doing some hinge modification I can't get my wheelchair in the car easily. So if I didn't get it to work I'll probably just get another bmw again. I really want to try an SC though.
Maybe this is a little redundant relative to things you may have already considered, but is there possibly another type of wheelchair that may fold smaller or squeeze into smaller places to "accommodate" an SC400?
There's got to be some way to make it work if you really want a specific car...
The door is designed with a fade away design and opens unlike any other door as it is already since it moves away from the car rather than simply pivoting. Any movement more than it already does would put it in the fender so it's at it's limit. You can remove the bolt that secures the tensioner and may be able to gain a little more movement. I have a thread on doing it, so search my user name and door hinge.
