SC- 1st Gen (1992-2000)
sc300 on 19x10 what offset to get?
Old 11-18-07, 12:48 PM
Star08
Star08's Avatar
Default sc300 on 19x10 what offset to get?
ok I have a general question.
all you ppl using 19x10 or wider,what offset are you using?
I want to run 295 in the rr and want to know what offset to get.
I'm coming from the fwd world and now have a rwd car as my new toy,thanx in advance for your help
Old 11-18-07, 01:09 PM
bigmalik00
bigmalik00's Avatar
+35 , but there is a sticky....you have to read the whole thing. Its worth it
Old 11-18-07, 03:44 PM
vinh
vinh's Avatar
+22 and run a 265 tire
Old 11-18-07, 03:58 PM
5sp_jzz30
5sp_jzz30's Avatar
it will all depend on how much effort you want to put in to make it fit and the look you are going for:
if it was me i would get 19x10+0 or low teen offsets. i would roll and pull the fenders, and run a 245 stretch. and maybe more negative camber(like -3 degrees or so) to make sure they tuck in nicely. its a low of work but looks amazing. also with a lot of camber your tires wont last as long. so if you dont care about tires then its ok.
if you just roll the fenders and use a 295 tire (which is unnecessary in my opinion) you need some +35ish offsets.
why such a wide tire? are you putting down some serious hp and have traction issues?
Old 11-18-07, 04:18 PM
Blizzy
Blizzy's Avatar
I have a 285 at a +35, and it is tight. On a 295, anything between +40 and +50 will be golden. A +50 can handle a 315 is you wanted some massively wide meat.
Of course, you would have to roll your fenders; and, there is no way in hell you could fit such a wide tire up front. The largest I have seen is a 275 up front.
Old 11-18-07, 05:40 PM
Star08
Star08's Avatar
the car will be making 850 plus hp,And I've seen a 97 sc at a car show before with some 305 and it looked SICK.......
Old 11-18-07, 07:40 PM
gldndrgn14
gldndrgn14's Avatar
a +25 offset will stick out at least 1 inch both front and back.
Old 11-18-07, 10:27 PM
Blizzy
Blizzy's Avatar
hooking up with that much power on 19's is going to be tough to very tough. I would go 19x11+50 and run some 315 DOT Drag Radials to give myself the best chance of staying in touch with the pavement.
Old 11-19-07, 05:19 AM
Star08
Star08's Avatar
oh,btw I'm staggering the wheels,but I want to put the widest wheel in the back with the wides tire so I can keep this thing fm spinning.
So I tough 19x8.5 in the fr and 19x10 or wider in the back.but the key is to get away from modifying the rr fenders
Old 11-19-07, 08:52 AM
xcelr8
xcelr8's Avatar
I have 295 10s all the way around...looks great. Aggressive. The front srtciks out about 1/16 of an inch, but is undetectible because of wide front Vertex-like bumper. No rolled fenders, 30 offset. However, there is slight rubbing under big bumps or loads.
Old 11-19-07, 09:40 AM
booja
booja's Avatar
only if the car is not lowered
im on a +20 offset and it barely sticks out... well at least to me. the lip of my wheels are past my fenders but not by much
Old 11-19-07, 12:48 PM
Gunnar
Gunnar's Avatar
You want to put 850 whp down through 19's? Good luck
Old 11-19-07, 12:55 PM
Star08
Star08's Avatar
sorry the front of the car will get 245,and the back 295.sorry for the miss understanding
Old 11-19-07, 12:57 PM
Star08
Star08's Avatar
how low is your car?
Old 11-19-07, 01:16 PM
xcelr8
xcelr8's Avatar
My car has not been lowered by me. It did come lowered somehow (I cannot figure how...all looks stock) a LITTLE bit.
Quick Reply: sc300 on 19x10 what offset to get?
