Heater controls do not work; fuses = good
Just did a 1j swap. Climate controls not working, checked all the fuses under the hood and the driver side kick panel and the one right behind the climate control.
The center buttons light up (the fan up and down and then the ones right above it) and none of the others do.
checked up the glove box, that was plugged in.
i also read that it would have to do with the ignition because the CC is connected someway...... but no definitive answer.
any other things i should try?
i did do a search...... that is all i came up on it. check fuses..... done. replaced fuses..... done. nothing in my cigarette lighter. people say to check connections under the glove box.... done. check fuse on CC.... done. there is nothing else that came up on search... other then people syaing something about hte wiring on the ignition.... but no definate answer.....
AHHH tire fluid LOW!!!!! only air comes out!! haha, j/k. metered out the connections and they are there. I metered all the fuses under the hood and they read good, but metered out fuses under the driver side box and the HTR gets no power. so we hard wired it and still nothing.
Keeper of the light
