Help putting on 97 sideskirts?
Guys,
Been trying to get my 97sideskirts on my 93 for quite some time. I kept being without the correct mounting tabs/bolts so I ended up getting mad and ordering every bolt/nut/washer/tab available for the side of the car. Somehow, I still don't have the right thing.
I need whatever it is that goes into what I have circled
![](http://i131.photobucket.com/albums/p309/drinkdontdrive/sideskirttabs.jpg)
Anyone know what this part is?
Jonny
Jonny
Keeper of the light
AGAIN?!?!?
LOL
Hope you get whatever you need this time (before you set this thing on fire)
Those appear to be push tab receptacles (those plastic things that lock into place when you push them in a hole .... it works like you do
LOL
i think something like this goes in there
there are a billion different versions of this clip, slightly different shapes sizes and colours, but you get the idea
the top of the clip slots into the parts you have circled, and the other end of the clip goes into a hole
In fact, I spent just shy of $150 in bolts/tabs/fasteners and still didn't get the right ones
![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
Jonny
Wow lucky i only broke one of those babys .Its a yellow clip with a sort of plastic ball at the end of it, those are the ones that fit there, lexus should have them in stock you probably got the pre 97 ones .if that exists,goodluck finding it.
You think that is ghetto? I have done everything else right so don't want to cut corners, but this is killing me not being able to find this stuff out
Jonny
