SC- 1st Gen (1992-2000)
The HELL with MODS, Is your SC running right?!?!
Old 08-10-12 | 06:27 PM
  #136
SC400DAVE's Avatar
SC400DAVE
I repaired the carpet grommets today! Did it myself! Besides repairing the passenger door "wont open from the outside because the plastic clip broke" this is now the cheapest repair to date. And yes I repaired the door too!
I ordered some parts today to fix the back lighting in the cluster. Here is the AMAZING thread on that:
https://www.clublexus.com/forums/sc-...klighting.html
Can't wait to get that restoration under way!
Old 08-10-12 | 08:53 PM
  #137
Kayasith95's Avatar
Kayasith95
how about none of the above
Old 08-10-12 | 09:17 PM
  #138
SC400DAVE's Avatar
SC400DAVE
lol, Dang, that relentless pursuit of perfection gets expensive don't it?
Old 08-11-12 | 02:02 PM
  #139
The Ikon's Avatar
The Ikon
I betcha his car is mint!
Old 08-11-12 | 02:21 PM
  #140
chrisindub's Avatar
chrisindub
Default Runs awesome
I just drove it from las vegas to phoenix, drove all over phoenix, then back through flagstaff, williams and kingman AZ.
Ran perfect, AC ice cold, got 24.7 mpg one leg of the trip. Cruising 80-85 mph with cruise control on.
Attached Thumbnails The HELL with MODS, Is your SC running right?!?!-mmeteor-crater.jpg   The HELL with MODS, Is your SC running right?!?!-montezuma-s-castle.jpg
Old 08-11-12 | 07:46 PM
  #141
SC400DAVE's Avatar
SC400DAVE
Flyin down the road in a mint SC = Heaven on earth.
Old 11-20-12 | 10:32 PM
  #142
spitfire7's Avatar
spitfire7
All the above other than the lopping. J/K. its clean other than a few door dings missing a lil paint on the fender. mine has a low lopping idle. runs nice and smooth tho.
Old 04-08-13 | 08:03 AM
  #143
Maserati's Avatar
Maserati
Ive got a bunch to do, power steering pump, transmission fluid, my diff just broke so new diff, -_-
Old 04-08-13 | 09:31 AM
  #144
Studiogeek's Avatar
Studiogeek
I have put a lock on everything that has to do with looks and upgrades if it does not help the car or help me drive it. I need desperately to get my car back to stock body but instead, I just purchased the HUGE OEM timing belt/water pump/seal kit, plugs, wires, caps, rotors, engine coolant temp sensor, coil packs, fuel filter, thermostat and more. I went on and purchased and refinished stock headlights and put HID's in them as my Halo Projectors the car came with were so dim they were straight-up dangerous. The over the top body parts will stay on until i can drive this Bit&$ to Cali and back with no worries (outside of questions about my tastes ;-).
I did however splurge once and buy some used Work Wheels soon to be mounted and maybe dropped.
Old 04-15-13 | 08:42 PM
  #145
AC1984's Avatar
AC1984
Since last year I have replaced the brakes & rotors, cap, rotor, wires, plugs, valve cover gasket, alternator, shocks, battery,upgraded to hids, windshield wipers, fuel pump (twice) and fuel filter. I also, replaced and upgraded all of my speakers and my head unit. Next on my list is to redo my dash cluster and climate control. My interior looks like_____ and I am researching my options. If you have any suggestions... chime in.
Old 04-16-13 | 12:23 PM
  #146
Tommy2JZ's Avatar
Tommy2JZ
things ive done.
replaced calipers and pads (need new disks, saving for slotted ones)
replaced rack and pinion bushings
upgraded motor mounts
replaced both cam seals
replaced crank seal
replaced engine rear main seal
replaced tranny front main seal
replaced oil pan gasket
replaced transmission oil pan gasket
replaced high pressure power steering hose (steel braided custom)
repalced power steering return line, replaced a bunch of old vaccuum hoses.
rreplaced radiator
replaced pulleys with alluminum
replaced brake hoses
muffler broken, bought new ones
interior was trashed, replaced 90% of it. only need dash lol.
got oem floor mats, replaced battery
replaced valave cover gaskets
replaced distributor O ring
replaced timing/serpentine belts
replaced rear heater hose
new MAF ... i think thats about it? lol
Old 04-16-13 | 04:42 PM
  #147
chargerfan's Avatar
chargerfan
Originally Posted by Tommy2JZ
things ive done.
replaced crank seal
rreplaced radiator
all diy right?
how many hours of labor (roughly) have u invested into all that work?
Posted from ClubLexus.com App for Android
Old 04-16-13 | 09:39 PM
  #148
2jznosht's Avatar
2jznosht
This thread is awesome...I shamefully have to admit my sc is in desperate need of a paint job, but it seems like I have replaced everything but the transmission so far. The only reason the intake is on there is because it was 30$ shipped. The exhaust I had to have done due to emissions last month and hollow cats. Figured with the cats going in I might as well buy the Megan straight through style knock offs lol.
bighead222
16
06-08-11 11:28 AM
UTSC300
16
05-25-07 08:43 PM
O. L. T.
Automotive Care & Detailing
33
02-14-06 01:48 AM
TMaxxTim
09-30-04 09:34 PM
ChrisSC300
13
03-04-03 10:58 PM
