The HELL with MODS, Is your SC running right?!?!
#77
Originally Posted by Soarer_25GTT
Hi everyone...
I'm new to the forum...
Read page one gents... it was true then, it's even more accurate today
#78
Good bump
I need to do spark plugs, cap, rotor, and some other stuff real soon.
#79
Originally Posted by SupraCoup3
If that doesn't clue you in how vintage this thread is, I don't know what will.
Read page one gents... it was true then, it's even more accurate today![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
#80
I just wanna say thanks to anyone who listed stock parts that should be checked and replaced often. I am sitting her with a pen and paper and since I dropped my sc400 off at the shop today I will take this list over and have them look it over so I can fix these basic, but important things myself.
#81
*Can you get into your car and drive across the nation, state, region without fear of it not making it? Yes to both. Drove them over 600 miles a week alternating back and forth to Clevland.
*got those struts changed!? Yes in the SC400 and not yet in the 2000 SC300
*Stop your SC from missing or loping!? Not a problem
*Is your car smoking or knocking? Nope
*Got those worn out ugly seats fixed!? Look very nice in the 2000 and not too bad in the 400
*Got that busted speaker changed!? Perfect in the 2000 and yes in the 400
*got some new tires yet?.. Yep
*get your tranny and diff. serviced lately? Yep
*Is your power steering pump still leaking? Nope
*When was the last time you changed your plugs, wires, caps, or even your OIL? 6 mos or less
*Are you mats torn, worn and need of replacement? Nope
*does your dashlights work? Sure do.
*Does you interior look as good as new again? need a shampooing? Very nice indeed.
*Is your wind shield cracked? Nope
*Is your steering wheel a mess? Perfect in the 2000 and new American stiches in the 93
*When was the last time you changed your brakes? 6mos
*New pads huh... what about the brake fluid flushed? 3mos
*Radiator services, thermostat changed? Yep, 6 mos
*Did you get the AC fixed from last summer? It will be hot again in a few months! Yep, nice and colc
*Does your heat work? It better it's cold outside! Worked fine, VSV is fine
*Are the rotors warped or need of turning/shaving? Nope
*Is your paint CRAPPY? Need a buffing? Perfect, clay bar'd and buffed.
I am the upkeep man buddy!
Peace out,
P
Peace out,
P
#82
This is EXACTLY what I've been working on with my car, except for a few goodies here and there (new stereo and magnaflows
Makes me happy when I look back to see all the hard work I've put into this car getting it to where it is now, and then looking at the pics of where it came from. There's nothign better than the satisfaction of knowing you did it all yourself (except the new engine....thats still a little more than my craftsman tool set can handle)
Before you throw money into go fast goodies.... Answer these lil' question
New KYB GR2's
Yes, NGK plugs were the answer, no Bosch
Nope
www.leatherseats.com
complete new stereo system, new speakers all around
got GS400 rims and brand new tires
Changed the fluids in both after I got th ecar
Not yet
New (used) engine, NGK plugs, distributor, cap & rotor
Steam cleaned them all and they look great
OLT needs to fix this for me later this summer (or ratehr when I get money!!)
Algia hooked me up with some clean carpet
Nope
Yes...still trying to find a good cheap solution, its not too terribly bad yet
April '06 - irotors.com all around w/ new Raybestos QS pads
Umm...this still needs to be done
Ooohh man CHANGE YOUR THERMOSTAT!!! Its $10 and saves you from a $1600 new engine
Sure did, works great after I put the right amount of R134a in there, too much or too little and it doesn't work
Yes
Rotors are only 2 months old (but my high-speed stops have slightly warped them)
Bought the porter equipment and all the polishes and it REALLY makes a black car shine when you do it right.
I've always wanted to go turbo and have a fast car, but I also knew that if the car wasn't in good shape outside and inside its not worth spending the money to make it fast, then you just have a fast, crappy looking old lexus!! And thats no good
New KYB GR2's
Nope
Not yet
Nope
Yes
#83
Right on the Mark, Ikon!
My '95 SC400 has gotten the royal treatment over the past year:
New interior courtesy of a Group Buy from this site. 20 hours labor to install myself.
New OEM (yes, STOCK OEM) chrome wheels
New Supra TT LCA's up front, with
Vlamos bushes for the UCA's,
New Rear back LCA's, stock.
Timing belt
Water pump
tensioner pulley
A/C compressor
Tires
New front headlamps (Thanks, Carson Toyota!)
I'm sure I'm forgetting something, but still to come is Power steering pump, alternator, and, God forbid, paint (next year or two).
then, AND ONLY THEN will I think about performance exhaust, BFI, or other 'fun' mods.
This car is what it is: A luxury sport coupe. And a damn good one, even 11 years later.
tj
Timing belt
Water pump
tensioner pulley
A/C compressor
Tires
tj
#85
There has been so many threads about HP gains, ECU, NOS, intakes, AFC, turbos, mufflers, racing, rims etc... The big question is... IS YOUR CAR RUNNING GOOD enough!?!?
If your car has ANY one of these problems STOP worrying about racing, turbos, S/C and 0-60 times and focus on perserving your SC to it's proper condition... I want a sweet looking ride that is plush, posh with the pananche of a $60K car... That drives, looks, feels, and rides like a SC... Focus on fixing a problem with your car and bringing it back to glory... Then you can make it perform better...
The monies we spend on mods/rims can get that older Lexus in mint condition before we know it... If you have a new Lexus keep it that way...
The Ikon![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
The Ikon
#86
Such a great thread. Ive had my sc300 for a month and have driven it half way across the country once. So far, I have a new ps pump and a new battery. Bushings will be done in the summer when Im back in TX. I was hoping to get rid of the god awful rims that the previous owner had and replace them with more stock-ish rims.
Maintenence > Mods ...unless you cant bear the sight of your rims :P
#87
Rims are called errrrrrrrrr ummmm STATUS MAINTENANCE!!! ha ha
#88
Such a great thread. I was thinking all about POWER as i did with my Supra. But after reading this and thinking. I have a true sports car. I don't need another one. 3 days of driving my Supra and i have to fill it up agian. 6.94a gal isn't cheap. My car has about 205miles. it was bought used in 96 with 100k (poor girl). I just had a major service done. Timing belt, Tensioner, New pulleys...pullies ?, Timing covers, Valve adjustment(Sucks because they are the SHIM type.), Transmission flush ( i used motul ATF), New propeller shaft dampeners, Sill need alot of parts like LCA, Driver side door pannel, window regulator, radio, antenna mast, springs and dampeners NOT SHOCKS, and a repaint. SO all in all not to bad. I plan on doing the labor my self. She's getting alot more mileage. After i change all of the neccessary (ie the suspension parts). I plan on taking her to Willow Springs race track and see what times she will get with all of these parts replaced by aftermarket Race Inspired parts. IF IT AIN'T BROKE DON'T FIX IT,AND IF IT IS BROKE BY AFTERMARKET!
#89
*Can you get into your car and drive across the nation, state, region without fear of it not making it? - doesnt matter..it isn't a daily driver.
*got those struts changed!? - nope, but I will
*Stop your SC from missing or loping!? - engine runs fine
*Is your car smoking or knocking? - burns oil...no biggie, not keeping that engine anyway.
*Got those worn out ugly seats fixed!? - I will in a week
*Got that busted speaker changed!? - Nope, speakers aren't important
*got some new tires yet?.. - Nope
*get your tranny and diff. serviced lately? - nope, not sure it's ever been serviced...207k
*Is your power steering pump still leaking? - not leaking in the first place
*When was the last time you changed your plugs, wires, caps, or even your OIL? - got the car a week ago, never.
*Are you mats torn, worn and need of replacement? - I don't have mats.
*does your dashlights work? - Yes they do
*Does you interior look as good as new again? need a shampooing? - not even close to looking passable.
*Is your wind shield cracked? - Yes
*Is your steering wheel a mess? - Definitely
*When was the last time you changed your brakes? - Never
*New pads huh... what about the brake fluid flushed? - I said NEVER LOL
*Radiator services, thermostat changed? - Never
*Did you get the AC fixed from last summer? It will be hot again in a few months! - AC works fine
*Does your heat work? It better it's cold outside! - heat works as well
*Are the rotors warped or need of turning/shaving? - Haven't checked...can't see past the crappy rims
*Is your paint CRAPPY? Need a buffing? - I need a repaint and body work
The Ikon
[/QUOTE]
Funny thing is, I'm getting a 1jz and manual swap, and new interior. Cosmetic things don't bother me, as I know I bought the car for 400 bucks, and I'll try and return it to stock as best I can.
The Ikon
#90
The Ikon
$400 bucks!!! I'll give ya $601 for it!!!
