heater and a/c controls not working-HELP!!
My heater and a/c controls stopped working last night. All the fuses look good(kick panel and engine compartment). Any ideas?
thanks,
Craig
thanks,
Craig
does the air not come on at all??if it doesn't work at all then your blower motor or blower motor control module is busted..if it only comes on at max then(which is turned all the way up to highest setting) then its a good chance it's your resister, that is busted. hopefully it's the resister, blower motor/and or module costs a arm and a leg and is a PITA to install..
Neu`roc´i`ty
If you have the ability to change HVAC settings...i.e. Auto, temp up or down.
then check relays, fuses, blower motor.
If the screen is back lit, but no LEDs are showing and also your dash temp reads (-22) or (--). If this is the case.
Check the kick panel fuses. Twist the fuse slightly clockwise or counter clockwise. If the heat kicks back on, then its the contraction of the contacts because its cold outside.
I have the same problem like Craig - my heater and a/c doesn't produce any hot or cold air, although the fan is working fine. Furthermore, I don't have the fuse box diagram so I don't know where the a/c, heater, or cigarette lighter fuse is.
Please help me locate the a/c, heater, and cigartette lighter fuses. I really appriciate your help.
Thanks.
Thanks.
Geoff240ti
SC- 1st Gen (1992-2000)
07-06-07 01:55 PM
