SC- 1st Gen (1992-2000)
Think a stock SC can DRIFT???
Old 12-27-07 | 01:20 PM
Somy6's Avatar
Somy6
Default Think a stock SC can DRIFT???
Well i have a 95 5spd SC300. What do you guys think about takin it to a drift event. Does the car even have an LSD? I dont have any suspension work done either. I was just wondering if anyone tried to drift a stock SC300 and how it turned out. I am a good drifter but kinda need the car do help too you know. So is a stock SC a good drift car or not??
Old 12-27-07 | 01:24 PM
vinh's Avatar
vinh
no a stock sc is not a good drift car.
you can drift it in, but it is not a good drift car.
Old 12-27-07 | 01:27 PM
gorilaFART's Avatar
gorilaFART
i think its a good drift car...
just not in stock condition
needs mods such as lightening up the car as much as you can and the proper suspension works and hp
Old 12-27-07 | 01:29 PM
ISC400's Avatar
ISC400
and the SC never came stock with LSD
Old 12-27-07 | 02:10 PM
ja95sc3's Avatar
ja95sc3
Default SC300 drift
Mine is all stock. no mods but its driftable. A little underpowered but it works. A good 1JZ or 2JZ swap will sold that problem.
Check out some clips below.
Vid before the paint job.
http://www.youtube.com/watch?v=XmlpN76wgnQ
http://www.youtube.com/watch?v=KkiEbOzTx-s
After paint job
http://myspacetv.com/index.cfm?fusea...deoid=21982632
Old 12-27-07 | 02:30 PM
Somy6's Avatar
Somy6
Ok well obviously you do have a modded suspension. I also dont wanna change out the stock leather seats which is gonna suck. I am gonna be jumpin from one side to the other. Oh well, will see how it goes. If i do mod the suspension what would be a good start. Coils, sways, shocks???
Old 12-27-07 | 03:11 PM
5sp_jzz30's Avatar
5sp_jzz30
i drifted mine all summer long at drift days. all have is a welded diff, tokico/eibach combo, two grapefruit shooter mufflers and a JIC bucket seat. i put some 15x7 wheels with a 195 tire stretch on it in the rear. it drifted really nicely. plenty of fun its very underpowered but you just have to clutch kick the hell out of it.
Old 12-27-07 | 03:15 PM
Somy6's Avatar
Somy6
Sorry to ask, but what is a welded diff??
Old 12-27-07 | 04:02 PM
BLovesc's Avatar
BLovesc
Just get a good 2way lsd some coilovers and your set. Ive seen some drivers drive on that setup and do pretty well. Id say thats all you really need. Just have fun
Old 12-27-07 | 04:16 PM
5sp_jzz30's Avatar
5sp_jzz30
a welded diff is a diff that is open and the spider gears are welded so it is constantly locked. when you go around turns the tire hops a bit and girls ask if your car is broken it cost me 50 bucks to get it welded and its been holding up since summer. a welded diff can be thought of as a full spool used in drag racing applications. same concept. 2 way diff is 750+ and i dont wanna spend that much money on it. i dont mind the welded diff either.
Old 12-27-07 | 04:21 PM
JDMCelsior's Avatar
JDMCelsior
After paint job
If an AE86 corolla is driftable, so is the sc300. Underpower? no way!
If you weld the diff, you'll be good to go.
Old 12-27-07 | 04:34 PM
5sp_jzz30's Avatar
5sp_jzz30
SC is definitely underpowered stock only because its so heavy. clutch kick it a lot and youll be all good. make sure you dont have a stock clutch though. it wont last too long.
Old 12-27-07 | 04:59 PM
ja95sc3's Avatar
ja95sc3
Like he said. A Good clutch makes a big difference.
Old 12-27-07 | 05:58 PM
Somy6's Avatar
Somy6
Let me make sure i get the picture here. Weld the stock diff so both sides hold??
Old 12-27-07 | 06:04 PM
SC4_FI's Avatar
SC4_FI
i know the SC4's have TCS, but dont they have an LSD too?
yes, i think that is what he means
Quick Reply: Think a stock SC can DRIFT???
