HIDs on my SC300
http://soarercentral.com/sc-forum/me...tml?1199460183
Some guys here in Australia have replaced their lined covers with clear covers DIY for around $200.
Seems quite succesful.
i have mine partially delined, and i love the look of it. but i couldnt quite get it perfect. and when i saw those delined ones..those looked soo freakin sexy! i love the look and how clean it is. so later on down the road..i plan on getting those
Mortgage Slave
I know you are excited about your HID lights. They are certainly much brighter than stock, and a much better color. I do want to point out that the stock lens in the SC is not made for HID, and will tend to scatter the light pattern differently than a lens made for HID. Also, the cut off from the stock light will tend to be different as well. Try to at least keep your lights pointed slightly more down than stock so that you do not blind oncoming traffic. You may notice that many more people may flash you thinking your bright lights are on. Again, looks great, but if you do not do a full retrofit, this can be a problem...
Without rims on the car or body kit the car was looking old
so to bring it into 08 I got some 8000K Hids. Ne one else had the problem with simple plug and play HID kits not working cause the pins are backwards on sc? Cause they worked fine in a BMW but not in mine.... o well it took 30 mins longer but i wired up a relay with a 12v constant. BTW they look sooo freaking awesome
ENjoY! (When i get a chance ill post the ones with my digital camera cellphone isnt that great)
![](http://i88.photobucket.com/albums/k174/belement/0102081919.jpg)
![](http://i88.photobucket.com/albums/k174/belement/0104080127.jpg)
![](http://i88.photobucket.com/albums/k174/belement/0102081953.jpg)
plan on doing the the turn signal indicators with HIDs too just not sure of what color yellow or blue![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
ok, i have to sc400. i have some HID's i want to put into it. where did u guys hook up the ballast though? i was like looking and there's like no room. intake on one side, and battery on the other. also...so we have to switch some positive and negative wires then for them to work?
Peace out
Peace out
You would have a fair amount of glare with this setup and yes it may blind some oncoming traffic, but at least the headlights are projectors so its not too bad. Some cars I see around here have p-n-p hid kits in stock non-projector housings and its pretty annoying because there is a bunch of glare that is pretty blinding.
