The 92-96 look a like but are not an exact fit.
If you don't have a foglight switch on your steering column you do not have fogs (unless someone went out of their way to install it and connect it correctly).
mine point to the side as well.but not as much as yours. i think they are meant to because I opened them up to do the bonnet modification and the reflective sheild is shorter on the outside wall and longer on the inside wall. what year is your car? if they are 95-96 if you look through the vent beside the foglight you should see a 8mm nut. that is used to adjust the the aiming, to adjust them forward I beleive you will need to go clockwise.
