View Poll Results: What should I do? What would you do?
Voters: 26. You may not vote on this poll
Rear fender: Pull it, stretch it or leave it.
I bought 2 pairs of H&R 25mm DRM adapters and this is what it looks like on 275/30/19 on 9.5 rear and 245/35/19 on 8.5 front.
New offsets with H&R adapters:
Rear: 15+
Front: 15+
--Should I leave the rear fender the way it is?
--Pull it and match the fender to the tire's sidewall?
--Or get strecthed tires?
The front definitely need some pulling.
Rear: 15+
Front: 15+
for front the smallest you can go is 215/35/19. that is the smallest so you have no choice, and it will not even be much of a stretch. the rears you have plenty of stretching options, from mild to wild. but i personally like stretched tires under stock fender(with the exception of roll). since the rear is so high, maybe just a mild stretch. i dont know. i like my cars aggressive.
goodluck though
Charley
goodluck though
Charley
Are those 9.5 rears?
225?
Thats a pretty aggressive offset.
Holy crap thats gonna leave a HUGE amout of lip exposed. (if it can even be done)
I stretched 245's on mine and it was crazy looking.
I voted pull BTW.......If your gonna pull the front, you need to balance it out.
**EDIT**....my sig pic is with the 245 stretched.......I'm running 275's now on the back and 245's on the front
This is what I'm trying to do.
CL Member Name: Eggman
Rim Brand and Type: Super Star Leonhardiritt Waffe
Rim Size f/r: 19x8.5 and 19x9.5 yes weaksos
Rim Offset f/r: +11 (+26 w/ 15mm spacer) and +13 (+38 w/ 25mm spacer)
Tire Size f/r: 215/35/19 and 225/35/19
Suspension Setup:
Comment On Ride:
Fender Modifications: shaved all four corners
Any other comments: rear rubs on hard corners, and also with passenger. fronts could come out another 5-10 mm.
keep in mind the lower your car is, the more offest it can handle (camber). also keep in mind, offset clearance varies when you change rim diameters.
Picture:
it looks like it sticks out much more in person. i suck at pics.
some more pics of how it sits here http://charlescharlescharles.com/sc/
Suspension Setup:
Comment On Ride:
Picture:
