SSR Professors.... Donked! haha w/ Vid
Wheels are hot man. I have the same also in 19's. My rear lip is not as deep as yours but its ok.Im at 285 out rear cause my offsets are conservative being that i like a beefy rear.I added a 5mm spacer to my + 39 up front, looks flush to me w/o turning rubbing issues on moded fenders. I needed the 5mm spacer cause i run tt brakes(clearance) and it helps with looks. Same SBC spoke color and polished lips. GL
AHH.. so this is what youre maybe after!!! I like Equips too .LOL you know. just funny
Meisters look. slight difference in spoke curvature but better lips & custom offsets offered from work. This is the best alternative.
1 out off 5 in my all-time favorites in wheels. Discontinued sp1's
Thanks for the compliments guys
275 in the rear will definetly be an option. These wheels were on a S14 and the guy tried to get the 10.5 rear to fit his S2000 by putting a 245 on it. Well it sorta worked, but its just way too large for the car lol. Im going to pull the 245's in the rear and keep them in storage and throw 275's on it, whenever I get the money for that, haha.
wheels look awesome.. with a 10.5 inch wide wheel there is no question if you can fit a wider tire or not. You could fit a 315 tire back there easy on the wheel but not on the car. With the offset you cant fit a wider tire to fit on your SC, a wider rear tire isnt going to work for you if you lower it. I have similar wheel size and run a 245 rear. Without some majow fender work you wont be able to lower it with a wider rear tire. You actually need the tire to pull in like it does to get inside the fender. Dont worry though, Once you drop the car the rear stretch wont be nearly as noticable because the tire will be up inside the fender ( if you do it the right way )
