98 SC400 "TELESCOPING WHEEL" Problems
I have done a search for a fix for this and can only find info on the TILT STEERING WHEEL PROBLEMS. My steering wheel does not go "IN & OUT" Some times it will function for a few seconds and than just dies. I have absolutely no grinding sounds. It is an intermittent problem, so it has me baffled. I do not know if the whole rubber washer fix, will work for my problem. I have tried searching as well as reading all 9 pages of the TILT WHEEL PROBLEM thread. If anyone has had any luck with repairing this problem, please HELP me. I would really appreciate anyone's input.
Keeper of the light
if you aren't grinding you can likely just blame the switch itself. Smooth mechanical operation and intermittent problems points to electrical. It could be a relay....... but is likely a switch.
(people who search get help
01, 98, bmw, electrical, issue, issues, mechanical, problems, sc400, steering, telescoping, tilt, wheel, working, x5
