SC- 1st Gen (1992-2000)
Picture Request - Cut Fenders
Old 01-21-08, 10:27 AM
RedPhoenix
RedPhoenix's Avatar
Default Picture Request - Cut Fenders
Im about to cut my fenders but I dont know how far down i should cut the fender lining.
Does anyone have picture of how they cut it.
Matt
Old 01-21-08, 10:31 AM
powerjunky
powerjunky's Avatar
i just rolled mine, i only did the top about 12 , then cut and bolted back-in the pcs of trim so it looks stock,except for the top.
make since?
Old 01-21-08, 10:32 AM
RedPhoenix
RedPhoenix's Avatar
yeah it does. if you were looking at a clock from where to where did you do it?
11-1? or what?
Old 01-21-08, 10:34 AM
AutoCoutureSC
AutoCoutureSC's Avatar
i shaved most of mine. from 8-4
Old 01-21-08, 10:36 AM
powerjunky
powerjunky's Avatar
more like 10 to 2.....i used the holes that the trim bolts into to make ea side looks the same. i retained 2 bolt holes in rear for cut trim and 3 in front.(trim was replaced to make stock apperance) if lowered. as a guide. i removed the trim,used a small cresten wrench to start the roll and the a nice plastic dead blow to get it moving and an old wood bat to smoothing it out like a rolling pin, took about and hour including the sand and repaint
ACleanSC4
ACleanSC4's Avatar
Here's a picture of my rear fender lip...that's as far as I'd shave it down...
Any thinner in that area would make it very weak...
Old 01-21-08, 12:17 PM
kyoso23
kyoso23's Avatar
Remove the trim and go from about 10-2. Make sure to not shave out too far to where you separate the inner fender. If you're extra careful on the front, you can save the tabs that hold on your splashgaurds and carefully bend them upward enough to be out of the way but still keep the splashgaurds intact. Take care when doing this not to overbend them or you can dent your fender. Most importantly, concentrate and take your time. When you're done, tape off the edges and apply a simple primer and rhino line the insides up to the edge since your trim will be gone.
Old 01-21-08, 12:18 PM
RedPhoenix
RedPhoenix's Avatar
Currently drying, I wound up just cutting basically 10-2 position, maybe even less
i also cut the black part to fit it, so it looks "oem"
i sprayed clear on it to keep it from rusting. Thats drying now, so hopefully this goes well.
Thanks for the help guys!
Old 01-21-08, 12:28 PM
kyoso23
kyoso23's Avatar
Post up a picture or two when you're done.
Old 01-21-08, 12:35 PM
pnyboy27
pnyboy27's Avatar
dang..those are some nice wheel tucks! i wanna get this done to my ride now! haha
Old 01-21-08, 12:44 PM
kyoso23
kyoso23's Avatar
Originally Posted by ACleanSC4
Old 01-21-08, 01:00 PM
RedPhoenix
RedPhoenix's Avatar
Now that its back together, I look at it. I dont think I cut enough now...
You be the judge. I think I need more taken off on the front of the car.
Old 01-21-08, 01:28 PM
reLXn
reLXn's Avatar
hmm...when i cut mine, it was around 9 to 3 but it was gradual(sp).... meaning the 12 o'clock was the deepest and the 9 and 3 was the least. i didn't cut beyond the spot welds.
Old 01-21-08, 01:32 PM
Kaydee
Hacked CL to become a Mod
Kaydee's Avatar
you guys are insane lol some nice fitments here...personally cutting fender is too heart wrenching for me...took me awhile to finally do my roll
Old 01-21-08, 02:22 PM
97-SC300
97-SC300's Avatar
kyoso23, man those rims look good.
ACleanSC4, ummm..... DAMN!!!
Quick Reply: Picture Request - Cut Fenders
