Changing my interior from tan to black (pix included)
#93
For the headboard dash part, I just masked everything up and painted it. I just had to be extra careful, but that's how I got it to work. If the part is not easy to remove, I would suggest just masking it. As good masking job takes a little less time than removing the whole piece. I don't really see why you can't get to certain parts though, perhaps you can show me a picture of the part you're trying to get to?
#96
basically its the part at the very bottom of the windshield... the very deep areas of the dashboard. and also the opposite sides of the vent area...
#97
hello, I just wanted to know, will that spray can dye paint work on my seatbelts. I have white seatbelts and are filthy black/brown. I want to just dye it compelely black.
where do I buy that spray can dye from?
thanks.
thanks.
#100
I used 5 just for the lower trim panels (doors and rear, plus center console). Add another 1 for the Dash. 2-3 For the pillar trim and rear deck. Figure 2 on the head liner alone. So I'd guess 10 - plus the clear coat and vinyl prep to go with it. Thats not counting the seats - which IMO I wouldn't do.
You can use less if you want, but I did multiple coats of black as well as the clear.
madchyers
IS - 1st Gen (2001-2005)
19
07-06-23 02:13 PM
