Best Toy Ever??? Soarer RC Car by HPI
http://www.youtube.com/v/p533DxCVhnc&rel
Video of the chassis
"The drivetrain used in the RTR Nitro RS4 3 Drift is protected from rocks and other debris by a solid shaft-drive system. From its first use on an off-road, big-tyre truck, the HPI Nitro 4WD system has been refined and perfected over several generations of HPI cars and trucks. From the clutchbell and spur gear set, all the way to the drive axles, this is one of the most solid drivetrain sets you can find in RC!
Large 1M (1 Module) gears spin the single-speed transmission, which gives you fingertip throttle control as you slide around the curves. It also lets you get up to speed fast so you can pound the corners one after another! Centre dogbone shafts drive the front and rear sealed bevel gear differentials, splitting power through heavy duty outdrives which drive the super drift Type A tyres. The 4WD shaft drivetrain in the RTR Nitro RS4 3 Drift is as solid as you can find anywhere, and is tough enough to take the power of the G3.0 engine and not worry about any debris wherever you may run!"
"Power comes from the potent HPI Nitro Star G3.0 nitro engine (.18 Cu. In.), with more than 2 horsepower and 32,000 RPM on tap for tyre-smoking drift action!
A large diameter aluminium tube manifold and an all-new rear exhaust muffler system routes the engine smoke out the back of the car for scale realism and
clean operation. The G3.0 is also equipped with a pullstarter for quick and easy starting.
A sturdy pull starter system, oiled air filter, 2-needle carburettor, aluminium flywheel, strong steel clutchbell and aluminium tube manifold complete the
power delivery package, making the G3.0 easy to start, run and maintain!"
http://www.hpieurope.com/kit-info.ph...n&partNo=10073
http://www.hpieurope.com/kit-info.ph...No=10073&hid=3
I worked at a hobbyshop for about a year or so, I have the HPI bodied one, I don't use Gas powered drift rc cars though, no point, I have brushless battery powered, I love it! Stagered wheels, got some Advans as well, hahah I love these cars! (the car is about 200 for everything if you get electric)
here is a clear Soarer wide body
http://cgi.ebay.com/ws/eBayISAPI.dll...m=110233690518
BKJasonp, it depends on if you want electric or nitro..
The HPI I ordered will be for sale once its finished be refurbished..i bought it used. i may supercharge it, not sure yet though..
its 310 dollers comes with prepainted body s15 or the soarer. its ready to run all you need is batteries and nitro fuel
i had a defected engine had so send it in ill have it back in a week or two but ill put up pictures of the sc300 body that i painted! i bought the s15 kit and gave the body to my friend and got the soarer body separate and that way i got to paint it myself, enjoy.
