SC- 1st Gen (1992-2000)
Size of Hole for Antenna?
Old 02-28-08, 05:08 PM
Luxor
Luxor's Avatar
Default Size of Hole for Antenna?
I know one of you has the antenna temporarily off for some reason..can you measure for me the size of the hole that the antenna goes in on the rear quarter panel? I plan on deleting the antenna and installing a flush plug, but am not sure what exact size to buy yet... Thanks in advance!
P.S. I also would like to know if the hole is round or oval shaped.
Old 02-28-08, 05:45 PM
JesLet
JesLet's Avatar
It is oval. It's not really hard to disassemble or take off the antenna. You need to unscrew the top part of the antenna and 2 screws inside and that's it.
Old 02-28-08, 05:54 PM
pnyboy27
pnyboy27's Avatar
where would you get a plug? i plan on doing the same thing
Old 02-28-08, 05:55 PM
JesLet
JesLet's Avatar
Shave it FTW
Old 02-28-08, 08:40 PM
Luxor
Luxor's Avatar
Dang oval? I may have a problem finding a oval rubber plug... I'd measure it myself, but i don't have the tools or the time at the moment to take off my antenna and to re-install it.
Old 02-28-08, 09:45 PM
JesLet
JesLet's Avatar
All you need is a flat-head screw driver and # 10. Twist the top of the antenna counter-clockwise.
Old 02-29-08, 05:34 PM
over40driv
over40driv's Avatar
Pair of pliers and a thick rag, does nicely. I have tried the antenna delete some time back, wanting to go with an inside, adhesive type, 12v. powered. Couldnt get reception in the burbs. so I went with a stubby. While I was experimenting with the antenna I cut an oval out of some same color 3'' wide stripeing tape. Worked well for a couple of months.
Old 03-01-08, 02:27 AM
c2ispy
c2ispy's Avatar
Originally Posted by JesLet
Shave it FTW
I 2nd that.
theazz
05-22-15 02:48 PM
vizcounty
IS - 1st Gen (2001-2005)
05-09-02 10:39 PM
Quick Reply: Size of Hole for Antenna?
