Window Help !!
Window Help !!
today I was driving my sc and it seemed as if the passenger window was under some type of stress..but i didn't make anything big of it...so NOW it only tends to go up and down from the passenger side and i could only ROLL up the passenger side window from the drivers seat....CAN SOMEONE HELP me please..
Mine does something similar. The passenger side window rolls up/down a lot slower than the drivers side (2-3 seconds) regardless of which side you do it from.
Mine might be a motor issue, but yours could be fried wiring or something of the sort.
Check the fuzzy strip that touches the glass from the inside... when it starts to go bad it doesnt let the glass come down freely and strains the motor, when the motor strains too much it will stop so you wont burn the motor.
let it soak in too or it will streak your windows for a long time.
soaring it sounds like your drivers side switch has bit the dust.
if your window operates fine from the passenger side,
one of ordinary skill in the art would easily derive the problem either lies with
the swith itself or the wire connected to it.
good luck!!
