Will It Fit{pls Help**
Hello, I Am About To Get A Set Of Mrr Gt1 Wheels For My 1995 Sc400,it Will Be A Set Of 20inch Wills Which Will Run Front 245/35/20 And 275/30/20 For The Rear With Some Nitto 555 Tires. Will This Set Fit Without Need Anything Needed To Make The Wheels Fit
Hope this helps.
Wheel: 19x8.5 +30 = 19" diameter wheel, 8.5 " wide and the wheel mounting surface (mounts against the rotor/hub) is 30 mm from the center, as shown in the pic.
Negative offset wheels will have a very deep dish look, but few cars if any can support a negative offset wheel.
I have 235/35/20 Nitto 555's on the front and 275/30/20 on the rear with a +40 offset and I'm lowered on Espilirs (pretty low). They are 8.5" wheels front and back and I had to cut & roll my fenders after getting to a proper camber setting.
thanks you all, I will call the shop and check on this info and get back with u all . Secondly what is done by cutting and rolling the fender
