View Poll Results: GOOD HANDY GUIDE
YES
![](https://www.clublexus.com/forums/images/polls/bar2-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar2.gif)
![](https://www.clublexus.com/forums/images/polls/bar2-r.gif)
![](https://www.clublexus.com/forums/clear.gif)
20
95.24%
NO
![](https://www.clublexus.com/forums/images/polls/bar3-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar3.gif)
![](https://www.clublexus.com/forums/images/polls/bar3-r.gif)
4.76%
Voters: 21. You may not vote on this poll
Sc400 How To Replace Old Door Regulators Step By Step
#91
I've don't his about 5 times trying to fix the rubber puck isolator the gears nest in, they keep breaking after I epoxy the deteriorated ones. Well i finally found the culprit. The rear guide roller was broken so the window cocked in the tracks and licked up, taking the gear with it. I replaced the roller (delicate 'operation') and now the window travel is smooth as silk again after I replaced the broken rubber puck with a junkyard pull.
RudysSC (07-14-23)
dean s
Performance & Maintenance
05-25-17 12:09 PM
201, 6980124033, 6980124041, 6980224032, 6980224033, camry, change, factory, lexsus, r, regulator, replace, replacing, sc400, speakers, toyota, window
