Broken Ds Window, Door Wont Unlock
so my window broke while it was down. the regulator broke for awhile now and i tried pulling it up with some pliers and i broke the window glass is everywhere inside and i got a lot o of it out now. at first the door wouldnt shut. but i got it to shut but now it wont unlock. even with a key or manually. i can still used th e master lock to unlock and lock the pass door. i know i need to replace the regulator and glass. but why isnt it unlocking? anyone has any info? thanks.
hit me up via aim. i saw your car today in the parking lot of starz and was wondering why your window was down....
hahaha yea bro i keep getting wrost and wrost luck with the car. i dont have ur aim actually. hit me up on mine if u can or ill pm you. yea i was there chillin with a friend. howd u know i wasnt there for crawfish? haha
You get your window fixed yet? I wonder if it happens to be a matter of 2 things breaking at once? Well before you replace the lock cylinder or the lock motor see if there on the same circuit by chance. Cause if you overloaded that circuit you could have blown a fuse. Or you can test the motor by hooking up a 12 volt power source to female connector and see if it functions. Use a volt meter to see your readings. See if you are getting a 12 volt power source from the male connector coming from the power distribution block. Does it make noise on the drivers side when you try to lock/unlock it? If it does it just might be the mechanical linkage that could have fallen apart possibly.Keep me updated later>>>>>
Hi, I have similar problem, fixed broken plastic piece on the rod to the actuator, it worked for a couple times, now rod goes up and down nicely, but will not unlock down (release lock).... does the actuator go our? Ps, you can see and hear it lock and unlock via the door key lock... door is currently stuck with lock in closed position, so I can't even close my stupid door!!!
Blaizze
12-12-13 02:44 AM
LS400BL80
12-09-13 04:31 AM
