V8 Tuning
V8 Tuning
I have some thoughts for all you tuning guys. Many times when I push my V8 hard, I notice that it pings. This is apparently normal and indicates that the ecu is optimizing timing. If this is true, how can you further advance timing as is apparently done with the weapon r ecu??
Secondly, it has been noted that these cars run too rich which is probably reducing power. The ecu's adjust for this an maybe a lot of the incrrease in power is coming from this. What are everyone's thoughts on using an adjustable fuel pressure regulator to allow the car to run more lean without changing the ecu.
Raj
92 SC400
93 RX7 R1
00 A6 2.7T
Raj
92 SC400
93 RX7 R1
00 A6 2.7T
There are several ECU upgrades to optimize timing and fuel. Check out old threads. I've heard nothing but good things about them from the people who bought them.
Pinging is NOT NORMAL in our cars. If you're getting detonation, check the gas you are buying or get the ignition looked at. You can damage you motor severly if this goes uncorrected.
Keith
P.S If your detonating now, don't even think about an ECU upgrade untill your problem is fixed.
And again; nice to see another Rotary guy on the forum!!!
Keith
Keith
Keith
what can the pinging be? Can it be low on oil? The other day I made a fast left turn from a complete stop, I heard(windows were down) what sounded like pinging coming from lower engine bay. I had 0w30 M1 and its been approx 3k with this oil.
thanks for any info in advance.
Define your "Pinging"
The common use of the term is for detonation. Sounds like marbles rattling in a coffee can. If you get this, then have your timing checked because detonation is a common side effect of over advancement. Poor gas can cause detonation as well. A lot of places have a special "winter" gas during the cold season which is notorious for causing detonation.
The problem could just be something loose under the hood. I'd get it checked out by a professional. Low oil shoudn't make a noise. Check your oil and top it off if its low.
If you ever hear pinging in your rotary - turn off your car; engine is about to go bye-bye!!!! Rotaries can be abused to all hell, but don't take an ounce of detonation.
Keith
Keith
Chicago Lexus Club Moderator
When was the last time you did a tuneup? Perhaps your rotor or cap is worn out and causes detonation. Go do a dyno of the car in question and look at the curve, if it's jumping all over the place then you have a problem.
DIrEctQL, are you actually recommending that he dyno the car to diagnose it? I've watched you post here for awhile, and you continue to give people the wrong advice. I'm not trying to start something, but if you don't know, then please don't answer, you're going to cause someone to damage his car one day. Dynoing a car puts heavy loads on it, as you know, having been to a dyno, and you want him to take his pinging engine and run it up to redline repeatedly so you can analyze the horsepower, torque, and rpm graphs? How will that do anything but put a hole in one of his pistons? Rboorgu, listen to Keith, he knows his sh#t, you most likely have a timing problem. The knock sensor should detect repeated pre-ignition and retard the timing accordingly, if you are still hearing detonation, get this taken care of ASAP. Oh, and Keith, those rotary apex seals luuvv detonation, lol.
I doubt detonation would be that visible on a dynosheet.
Do a good tuneup; as in replacing the plugs, wires and diagnosing your distributor. But having a bad plug from what I've seen won't CAUSE detonation unless its severely screwing up; as in causing a delay before spark. Plug gaps may need to be checked too
But heavens NO, don't take it to a dyno if youre pinging. That could surely blow the motor sky high. Check your ignition components first starting out with the simplest stuff like plugs and wires.
If its not your ignition system (which it most likely is); make sure your fuel pump is working right; and check the injectors. These fuel components, among others, may be getting whacky at high load and causing a lean condition.
Originally posted by DIrEctQL
PS. If knock sensor didn't detect the repeated pre-ignition and retarded the timing and he's still hearing the pinging problem why didn't the sensior rethard the timing to correct the problem somewhat? I mean if he's still hearing it, why? Quite possibily you're giving him bad advice as well. Am I right or am I wrong. All and all, he won't be fixing the problem by himself so he will most likely see someone who can.
most stock knock sensors will NOT detect pre-detonation at WOT... i'm talking like 99.99% of them
Keith
Keith
As for the oil, it was 1 quart low(could this have been it?)
thanks,
this was the first time hearing this pinging sound(marbles in a coffee can). You said that the knock sensor would adjust the timing to prevent this, does this sensor info get saved in cars computer? If so will the diagnosistic computer detect this info?
thanks,
