Will this wheel / tire fit my SC400?
I was just curious if my set of FIKSE wheels that are currently mounted on my 98 Supra Turbo with stock suspension will work on my father's 98 SC400 with stock suspension. I called Fikse and found out that my rear wheels are a 18X11 57mm offset with a 295/30/18 tire mounted on them. The front wheels are 18X9.5 with a 44 mm offset and 265/35/18 tires. Have any of you guys run similar size wheels and tires. Thanks for all of your help.
I think they'll fit. The front should fit no problem, there are other members on here, including myself running 18 and 19X11 with much lower offsets than that, but a little less tire. I think it should work though.
I have been looking at some custom made 18" rims. I took my rear tires out and 12" would be the max and 11.5" is prefect with 56 mm offset. From the face of the rotor and with 1/2" clearance from the springs, 8" is what I got.
Thanks for the help guys. I tried the tire guide but did not see anything exactly the same as my specs. As far as just mounting them, easier said than done. The cars are 300 miles away from each other at the moment. Thanks again.
98supra6sp
SC- 1st Gen (1992-2000)
01-05-10 04:21 PM
EyeKutr
10-09-07 06:09 AM
Gernby
Wheels, Tires & Brakes Forum
13
04-13-07 03:00 PM
