SC- 1st Gen (1992-2000)
Will these fit?
Old 05-16-08 | 08:36 AM
SATXSC400's Avatar
SATXSC400
Scott, Paco, and Clevercat thanks for the help. Man I have a ways to go to catch up to you guys..!! Nice cars guys. As more info is compiled it seems like those +30 front offset and +25 rear offset is going to be TOO aggressive. What offsets would everyone recommend? I'm thinking about just picking up a set of the Linea Corse 19" Wheels 19x8.5 Front - +30mm offset and 19x9.5 Rear - +30mm offset from Wheeldude. How would that look? Thanks..!!
Old 05-16-08 | 09:35 AM
clevercat's Avatar
clevercat
Really depends on what you are looking for...
You can even put 20x8.5 and 20x9.5 on rubber bands for show.
You probably need more than +30mm in front if you are performance oriented and thinking about the front brake upgrade in the future. Last thing you need is putting ghetto spacers on between your wheel & hub.
I think you should ask Wheeldude about offsets.
They should know. Tell them you will install the aftermarket spring & shocks and you want to get as agressive as possible. You should consider buying from someone else if they are unable to answer you.
I ordered and returned the Rays 2 piece Wolf77 wheels from Discount tire for my Z32TT about year ago. The sales guy said it will clear the front brakes so I purchased them. The spoke hit the front caliper during fit check. I returned them without question from Discount tire. By the way, check out MRR GT1s. They are pretty good quality wheels for the price.
Good luck!
Put up some pix once you get the wheels.
David
ricky350is
10-21-16 11:02 AM
Toster24
06-25-13 09:18 AM
wirelesstj
04-25-12 01:13 PM
TheSyndica
06-28-07 08:18 AM
2jzz30
13
04-18-07 08:50 PM
