Gas Door Stuck
Gas Door Stuck
ummmmmmm I have a rather interesting problem. I got gas today and I shut the gas door a bit to hard and now its stuck. I have no idea how to open it now, I tried to use the lever to pop it again but nothing
you'll probably have to have a friend pull on the lever while you pry it open by hand, or push on the hinge side and try to get it to pop open. if you cant get it with your fingers, insert a screwdriver (with a rag between it and the paint to prevent damage) and pry it open, shouldnt take much force. When lifting on the release lever you should hear it trying to unlock it at the fuel door, if not the problem could be at the lever itself and not at the door.
Once open see if there's something visually wrong with it you could possibly fix yourself. Its most likely the retaining clip opposite of the hinges that is tweaked.
Thank you for all the help sadly the damn thing is still stuck in there. I tried everything listed and it wont budge, almost like it is being held in there by something
gee no damage yet though right? does someone have a layout page on the gas door. see how the mechanism is and them investigate before we brake something :X or i should look at my gas door...
spxChrome
15
08-17-20 09:30 PM
THE_CEO
SC- 1st Gen (1992-2000)
02-04-03 06:40 PM
