gauges stopped working [Long]
I had most of my center console out today on my sc300 in preparation for the clutch install next weekend and anyways i had the stereo out and was just making sure everything was connected back their when i heard a POP like it was a fuse, anyways now on my instrument cluster, i have no lights and the tach and speedometer complety stopped working, all the check engine lights, oil lights still light up before i start the engine, also, my power seats only work i have the key on the first turn, in other words with the ignition turned off, i checked all the fuses under the dash today including the gauges one and ecu's and i still have no power, im very confused now, any help is apreciated, thanks in advance
Something similar happened to me recently when I replaced my dash. My problem doesn't sound exactly like yours, but similar. I never had a pop. My check engine lights, etc would work. When I turned the key to ON, the clock would go out and the odometer would be messed up. The tach and speedometer didn't work at all. I checked all fuses and everything was fine.
For me, it turned out to be a stupid mistake. There were 2 ground bolts that held down the wire harnesses on each side underneath the center console, by the shifter. I didn't bolt these back down before I put everything back together. Everything has been fine since I put those bolts back in. I hope your problem is as simple as that.
well i unbolted one wireing harness from under the stereo, but i thought it just held it down and that was it, so i guess they bolted it down for a reaon?
bryan767
Performance & Maintenance
11-07-19 06:24 PM
SeattleGS3
12-16-09 11:31 PM
