Fitment question?
Fitment question?
Sorry to bother anyone and im sure it has probably been posted before but do you think this wheel fitment is good for my SC400:
19x9.5, +25 offset on 245/35/19
19x10.5, +24 offset on 275/35/19
Thanks in advance for anyones help.
The first 'Sticky' in this forum is Wheel and Tire Fit. Guide so this will probably be locked, but:
I think I know which rims you are wanting to buy: The Work S1 3P's in the classifieds? Am I right? Should be the perfect sizing for an SC! Fender roll, or cut will probably be necissary from what I've seen. I don't think you'll have to pull much if any if you cut the fender lips...
I have 18x9.5 +20 with 235/40 all around and I had to roll my fenders. With your rims being an inch bigger, I think you will need a 235 up front, and problably a 255 in the rear. Other than that it will rub.
These wheels are very aggressive...You will need to stretch the tires a little more and roll all fenders to make it work...Otherwise, you'll probably need a slight pull with the setup you're thinking of....
istundra
11-24-08 08:22 AM
masboy
09-28-07 12:42 PM
