How Accurate is our MPG"real-time" gauge vs Scangauge?
I just started driving my wife's SC 97 400.
On a fairly flat road, the mpg readings fluctuated from 27 mpg to 36 mpg.
There was only the slightest increase in slope.
Are these gauges as accurate as scangauge or is our computer readout bogus ?
OLT,
The issue is not that the mpg may be off a small percentage due to the non-stock tire.
What I am asking is,
Is the real time digital readout supposed to fluctuate that much on a "fairly level" surface. As the level goes uphill, the mpg goes down, this does make sense, but
at going 65 mpg, my readout claims I should be getting closer to 30 mpg which is no where near what is accurate in "real life".
So, is the Scangauge a better tool or computer than our stock system?
OLT,
Click your mode button a few times to see your average. The real time one is only giving you a reading for that very second not an average. I reset my average mpg clock on every tank, it's usually between 23-25 mpg for the whole tank on my SC400 (with the AC on). The gauge on the car will be every bit as accurate as any of the aftermarket gauges assuming your overall tire diameter hasn't really changed.
And, if you calculate manually, eg: total miles divided by total gallons of tank , do they match ? That is pretty good for a V8.
So, for each tank, I need to "hold in" the button for average mph, mpg , trip etc?
Sorry for asking this neophyte question.
Thanks
Kyoso, are you actually getting 23-25 mpg from every tank?
Thanks
Thanks
I have been monitoring MPG closely over the past few months... Every time I run a comparison between a manual calc of miles/gallons with which I fill up and the computer, the average is at most .3 MPG different than the built-in computer average. That being said, I would say it is fairly accurate...
City driving yields terrible MPG on these things... revving over 3k often can put you at 15MPG, easy. I have been taking it easy the past few weeks and can now average ~18mpg with mixed city/hwy driving (usually get 24MPG on the highway).
Keeper of the light
If your gear ratio has changed form say... a TIRE CHANGE and it is running faster than it should any change is multiplied when the load is changed, but since you'd rather answer your own questions rather than mine,............. be my guest.
OLT.
I answered your question.Potenza 225/50/16 is the tire size.
Yes, There was a tire change, there is a 3.46 % difference in speed.
There are 808 revolutions per mile on the stock tires , and 837 revolutions per mile on my tires.
It would appear that , if what you say is true , is true,
And if you said its true, therefore you must be correct, there is a fairly large fluctuation in mpg in real time mode even on fairly small height changes in road surface.
No one is doubting your knowledge. You are still the king here.
It was just a question.
....and have a great day.
Last edited by Lexicon1; 07-05-08 at 03:41 AM. Reason: to include tire size that was in my previous post from header
