help with removal rear view mirror
I was trying to replace my rear view mirror, and there a hex screw.. It is screw in tight as **** and can't get it unscrew.. It actually broke my hex screw driver, that how tight is it. Any other suggestion or ways to remove it??
Also the mirror isn't auto-dim, so what does that button do?
The hex screw does nothing for removal
You must hold tight and pull it by hand towards you with all your might until it is removed...You may need to brace yourself before doing this...Watch out and make sure you don't lose the small metal ***** that holds the mirror in place...They will go flying (because of momentum of the force) once the mirror is removed...
What is the hex screw there for??? i thought if you remove that, the mirror slides off... Anyways, i know my mirror doesn't have auto dim, but what does the button do?? since it hook up to a wire too.
LEXuriouss
SC- 1st Gen (1992-2000)
01-22-07 12:46 AM
